Question about E-Machines eMachines Desktop PC
Video I just replaced my power supply in my s2485, everything powers up but I don't get video whether using the on-board on an AGP card. Can't figure this out!
  • 23 Answers
Hello kensansom766,
If everything is powering on and your getting no video, most likely the motherboard has gone out. With a agp card present it disables the on-board vga. Does it sound off any beep codes when you cut it on?
First thing i would do is take the memory out just to make the computer beep and acknowledge that there's no memory present, if you don't hear a beep, there another problem, if it does beep however you can assume the motherboards okay and go onto step two. It just might be bad memory too, see if you can replace it with memory from a working computer.
If you've been taking out the video card alot, i would make sure its seeded properly. Then take out some of those cards your not using. 56k modem, sound card, etc. I would also try just the on-board video, too.
Then if your still getting no video, i would remove everything from the board, ide cables, cards, usb controllers and cables, just have the power supply and the wires for the power and reset buttons connected. if you dont get at least the post screen, then its a bad motherboard for sure.
Sorry to type an essay, buts thats how i approch video issues like this. If you don't feel comfortable with doing major surgery like that, please don't. Most likely you can take it to a repair center and at least get a diagnostic, and put the fear of making things worse, in there hands.
Good Luck
CoDoc
Posted on Nov 06, 2008
No video from motherboard even with new video card
Dear sir,
if this board has AGP slot, try to use AGP card inspite of PCI display card .. second thing when u power up the board . short its crystal oscillator for 2 second during switching on ..by screw drivers..if if it will not provide display .
then open fan & reinstall CPU .. if cpu is OK ( only can be tested on other board ) ..then something is wrong with Northbridge ../ or power supply mosfet of board if fan is not running ..
Regards
raj
Jan 26, 2011 | Asrock P4i65G Motherboard
I am using intel desktop motherboard D865GSA but no display this board, i am change the ram,power suppley ,smps, processor. this problems mainboard.on the maiboard supply working only 10 sec and shut...
More than likely your on-board video card is bad, buy a PCI video card or an AGP card and replace the video board. when you boot up go into bios and disable on-board bios so the computer will detect the new video card. hope this helps.
Aug 07, 2010 | Intel 865G Motherboard
Video black with 7600gs card installed
Hi bandit11,
First how did you get a PCI-Express X16 like the 7600 onto a AGP 4X port?? Two different animals. To answer your qustion, no that Card will not work on that Board. You can spend your money if you want to on some of the higher speed video cards but, to be turthful, I wouldn't. The CPU and memory will limit any of the newer cards that will fit that board today. But, if you really want to keep that board, then I might suggest to look for a $40-50 Radeon 9700 pro or 9800 pro. Anything more than that is a waste of your money.
Bottom line a lower end AGP cardwon't give you any more card performance then high end AGP card if you must upgrade, go used and cheap...nothing fancy.
Best of Luck
Mark
Dec 11, 2009 | Syntax SV266M Motherboard
I have an HP Pavilion a1777c with a blank monitor
If the computer is starts up normally other than the no-video problem (that is, you hear all the normal sounds from the computer and the usual Windows startup music), then you probably do need a new video card. According to HP's spec page for the motherboard used, you'll need a PCI-E video card. Don't confuse this with a regular PCI card which has a different connector.
The spec page also says the board has integrated graphics. so you could remove any video card that's been installed and try booting with the built-in video. If everything else is working properly you can use that until you get a new expansion video card.
If the trouble is that the computer's not booting at all even though it's coming on, you'll need to figure out why. This might be a memory or video problem, although these usually cause some beep code if the motherboard gets into its POST (power on self-test). If nothing at all happens, this is often the sign of a bad power supply, processor chip or system board.
Jun 16, 2009 | HP Computers & Internet
Powercolor Radeon 9550 R96 256mb Card - Lights on, noone at home!
Depends on the video card ,it might require more power ,200w is fine for onboard but add other components and the system needs more power.
Disconnect the harddrive or CD ROM drive and see if the system will start.
If it starts then you will need more power 300-400w at least but shuttle power supplies can be expensive to get.
May 18, 2009 | Power Color RADEON 9550 R96-LC3 (128 MB)...
Is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
ATI has recently written some better drivers for the 2400 Pro AGP cards,... Make sure the setting in the BIOS for the motherboard is set to the AGP or PCI for primary video. For AGP, make sure that you have the power from the power supply connected to the video card. Make sure that your motherboard does support 8X AGP video cards. If you are not sure, please check with motherboard manufacturer for compatibility.
Dec 13, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
Ati radeon agp card
Hi Rafael83,
There may be afew things that may be wrong. One, the video card may be bad, two the motherboard may be bad, or three your power supply may not have enough wattage to power your video card. Or it coud be all of the above.
Sincerely,
Agent Xiong
Apr 30, 2008 | Vga GeForce4 Ti4200 64MB DVIout AGP Card...
Video signal
If it worked fine before the AGP card was removed then the problem is probably related to your BIOS settings. The BIOS setting that controls the integrated video may be set to OFF.
  1. Insert an AGP video card
  2. connect the monitor to the card
  3. boot to BIOS
  4. check settings
  5. turn ON integrated video
  6. save and exit BIOS
  7. shutdown
  8. Remove AGP card
  9. connect monitor to motherboard video port.
  10. Reboot.
What happened?
Jan 26, 2008 | EliteGroup 661FX-M Motherboard
Will not accept new agp video card
Did you try and change the power supply? Maybe the power supply is faulty since u say it keeps rebooting. Since you do not see anything on the screen (the bios is not executed, could b a problem with the power supply. Do you get any beeps?)
Dec 24, 2007 | Asrock 775VM800 Motherboard
E-Machines eMachines Desktop PC Logo
65 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
