Question about Canon Office Equipment & Supplies
Iam getting error code E010,E014
Iam having ir6000 model canon copier in recent iam getting Eo10and E014 problem what is the solution for that.
  • Canon Expert
  • 1,326 Answers
A E010 & E014 have to do with the main motor drive. You may have a drum blade that has flipped or it could be that the center screw that locks the drum to the drum shaft is loose ( just tighting screw- you can also get blank copies as well. The E014 deals with the fixing unit, you have to make sure it is spinnig freely. It could be that the lower pick off claws have dug in to the lower fixing roller, or the ball bears are siezed or the web is rapped around the upper fixing roller or a bushing is broken or it may be to much pressure is on the UFR from the web... Just a few ideas.. Good Luck
Posted on Nov 07, 2008
Canon ir400s E014 error code problem
I dont know that model,but on the others it may be waste toner bottle full,or fixing motor faulty
Oct 15, 2014 | Canon Office Equipment & Supplies
000110-0001
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Jul 15, 2013 | Canon Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Error e014 on canon gp 605
I THINK E014 IS FUSER UNIT MOTOR.REPLACE MOTOR.DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Feb 22, 2009 | Office Equipment & Supplies
CANON GP405 ERROR E014 PROBLEM
when I start my machine the error code e014 appears and machine do not run.
Dec 24, 2008 | Canon imageRUNNER 400S Copier
Error codes
E000 and E001 is due to the laser unit, I can explain in more details.
E014 is due to the Dc motor failing
Hope this helps?
Oct 17, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Ir 220
E010 codes relate to the main motor or 24v supply through the interlock system. Check for binding in the main drive, or loss of drive voltage.
Aug 26, 2008 | Office Equipment & Supplies
Canon NP 6030 Error code E010
chiudere sportello superiore destro
Oct 04, 2007 | Office Equipment & Supplies
854 people viewed this question
old marine
old marine
