Question about Refrigerators
The fridge is not working although the freezer is fine. the fridge temp is showing 24 and i cant change it
    Scholar:
  • 60 Answers
Feel with your hand for the spot where you feel the cold air entering into the refrigerator compartment.
Look for something near the area that says more/less cold. Sounds like the air flow is stuck open allowing too much air from the freezer compartment entering into the refrigerator compartment. A refrigerator works off the basics of recieving cold air from the freezer compartment.
Posted on Nov 06, 2008
John Lewis Fridge Freezer - Freezer compartment is working, fridge light works, but the fridge is not working. Please help!
Leaving the freezer door open for extended period of time could have caused the evaporator to freeze up and prevent cold air being driven into refrig compartment. Unplugging it for 24 hours will give it a great chance to unfreeze. You can also check the freezer temps before you do this - bet they are no where close to the ideal of zero degrees since the ice buildup is an insulator and prevents the freezer compartment from going down to the correct temps. And if the freezer is not at least 10 degrees or less your ice maker, if you have one, will not work since it has a thermostat that only cycles the ice maker at 10 degrees or less.
Jul 23, 2016 | Frost Refrigerators
Hotpoint Rfa52 fridge not working. Freezer ok.
is temp or freezer control turned all the way up? set frig / freezer control in middle and wait 24 hours. do you feel cool air going in freezer from vent? if not change control as stated and see if you have air flow. control door to frig may also be broken or stuck
Jan 30, 2014 | Hotpoint RFA51 Bottom Freezer Refrigerator
Our Sharp refrigerator model SJ-F60PC. 4 doors, freezer at the bottom and fridge at top. The fridge section is not cold although the freezer section is working fine. Much appreciated if anyone can help!
Your defroster timer switch may be at faught. The defrost timer turns on a heating coil to defrost your frige. This is only a guess since I don't have the year. Do this: feel the walls if they are hard and they have no give to them, then your fridge is frozen up solid and no air can circulate. Unplug you fridge for 24 to 36 hours. Put towels on the floor to catch the water. If the defrost timer is bad it will defrost naturally with room temp. Plug back in after 24 to 36 hrs and see if bottom is now getting cold. If it is the defrost timer, the solution is not cheap. It's up to you to repair or invest in new. Good luck Google burdfrenzy
Nov 26, 2010 | Refrigerators
The freezer temp is fine but the fridg temp is 50 degrees. It will not get colder than that. I have left it off for 24 hours to defrost and turned it back on and this did not solve the problem.
try moving the temp around,then if you tryed that already then defrost your frige turn off completly for one day if that dont fix it check if switch is working,last thing is the change the compressor
Sep 10, 2009 | GE Monogram® ZISS420DMSS Side by Side...
KitchenAid fridge model KSRA22KNSS overfreezing
Yes it sounds like the thermostat, depending onmodel you can change yourself. Here is a video that shows how to check your compressor is working correctly.
https://www.youtube.com/watch?v=5LvTdvyIFyg
Nov 30, 2017 | KitchenAid KSRA22KNSS
LG LRBN20514ST Bottom Freezer Frig cooling problems
Set the temp to low not high and wait 24 hours to see if the temp has drop.Also make sure the freezer is not icing up anywhere.If it is please repost.
Jan 13, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
I have a fridge-freezer. the fridge is working fine but the freezer isn't very cold, its about the same temp as the fridge. I have changed the temp dial but this makes no difference.
I Have a fridge-freezer, the freezer is now filled with ice/frost on sides and top, as if it were not frost free. I addition, the fridge is not very cold
Jul 29, 2008 | Refrigerators
Samsung side by side srs580dw stops freezing and chilling
Since the temps on the display don't show correctly I'd assume something is wrong with that. If the temps are sending info out that the unit is OK and at proper temp (when it's not) then the compressor won't turn on because it thinks the fridge is cold enough. Soooo... I'd suspect that control board. It's item 48 on this diagram http://www.partselect.com/Schematics/Maytag/SS10-2.gif
Jan 13, 2007 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
