Question about Lexmark Office Equipment & Supplies
The printer says paperjam will not print out anything the paper allignment all to one side
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Nov 06, 2008
Canon irc3380i paperjam
This problem fault manual presenting the track. Follows to consider several reasons. Check the condition rubber roller seizure of the paper. Check and clean lower brake platform. Check and value the possible ragged sheet of paper. Check presence a stranger subject in giving device. Try to give the paper along on format by narrow side. Thank you, good luck!
Sep 16, 2009 | Canon C2058 Color Copier
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
Kyocera paperjam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Office Equipment & Supplies
Tally 2280+. While printing, goes offline and displays paperjam.
Dec 29, 2008 | TallyGenicom 2280 Matrix Printer
Paperjam
Cannon website says press <black> or <color> button to continue printing. Let me know if this doesn't work.
Oct 12, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Allignment
One possible cause could be -
The Form Size setting in the
printer driver is different than the
size paper that is loaded in the
tray. For example, you inserted A4
size paper into the selected tray
but did not set the Form Size to
A4.
Sep 01, 2008 | Lexmark E332n Laser Printer
Won't print anything
go to my computer
right click properties
hardware
device manager
?printer
scan for hardware changes
then try to print
Aug 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
