Question about Microsoft Office Professional 2007 Full Version for PC
Adobe 8.0 Pro corrupts MS Office 2003 Normal.dot file
Adobe 8.0 Pro was installed and all updates ran for both Adobe and Office. When you open MS Office 2003 the Normal.dot file gets corrupted. We have tried a reinstall of Office but the issue will reoccur. Need help
  • 849 Answers
Un-install and re-install office, or get the normal.dot file from other computer and copy it to yours.
Posted on Nov 21, 2008
How do I open a docx file without it corrupting.
Docx file is the default file format for MS word 2007 and 2010. If you have those application then you can open it easily. If you have the 2003 and below version, you will need to download the Office 2007 compatibility pack and install it to your PC then you can open the docx file
Apr 27, 2011 | Microsoft Windows XP Home Edition
I saved an .odt file from another computer and i can't open it in a 2003 microsoft word. what should i do to open the file?
Hi .odt files will not be opened by MS word as a default. Most likely MS Word does not have the latest service pack. For Windows 2003, download Office 2003 SP2 as a minimum (available from Microsoft)
Download, Install and reboot computer if required.
When PC starts, start up MS Word 2003 which will have SP2 installed.
Locate the ODT file and then double click it. As SP2 for Office 2003 is installed (or MS Word 2003) The file will now open. The formatting might be a little off, but for the most part, all the text will be there and you'll be able to edit and make changes as you see fit.
Sep 28, 2010 | Microsoft Computers & Internet
MY SYSTEM COULD NOT OPEN MS-EXCEL BUT IT CAN OPEN MS WORD
if you have the Microsoft Office DVD , you can repare MS Office instalation again ... I think the Excel will be repare also any file jammed and corrupted will be recovered correctly
May 15, 2010 | Microsoft Office Outlook 2003 for PC
"this modification is not allowed because the document is locked"
Rename all instances your document template files (Normal.dotm or Normal.dot) to prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened, rename your global template (Normal.dotm or Normal.dot). Renaming the template lets you quickly determine whether the global template is causing the issue.
When you rename the Normal.dotm template in Word 2007 or the Normal.dot template in Word 2003 and in earlier versions of Word, you reset several options to the default settings. These include custom styles, custom toolbars, macros, and AutoText entries.
Jul 12, 2009 | Microsoft Office Professional 2007 Full...
Links to Named Destinations Not Working
Ensure Acrobat 8 is fully updated (up through 8.1.4). Office 2007 support starts with Acrobat 8.1.0.
Some things to consider.
PDFMaker does not/cannot convert a file set as the target file for either a URI/URL or a UNC link path.
Regarding MS Word hyperlinks
May 01, 2009 | Computers & Internet
Unable to access word documents in office 2000 small business
why the .dot extension, it should be .doc. Better try uninstalling and reinstalling MS word or MS office package again.
Apr 17, 2009 | Microsoft Office Outlook 2003 for PC
MS word not responding
Rename all instances of your document template files (Normal.dotm or Normal.dot) This will prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened.
Dec 15, 2008 | Microsoft Office Outlook 2003 for PC
Office 2007 professional and Adobe 8 Professional problem
Very simple fix. Now and then after an Adobe Acrobat update Office will disable Adobe Acrobat as it is an add on. All you need to do is re-enable Adobe Acrobat. In Office 2007 goto Word Options, Add-ons, and at the bottom of the page is Manage. Click on the down arrow and select Disabled Items and click on GO. Re-enable Acrobat and you should be fine. In Office 2003, goto Help and selects disabled macros and re-enabler Acrobat.
Feb 25, 2008 | Microsoft Office Professional 2007 Full...
Adobe Acrobat 8 does not integrate with MS Office 2007 programs
Then do a search for 'all files and folders' - search for both Acrobat 6.0 and then Acrobat 7.0, with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those related files found.
You should do this search and delete whenever you uninstall any programs. It will remove lots and lots of leftover junk files and corrupted files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program. (Do this ESPECIALLY when updating to a NEW anti-virus programs and “Internet Security Suite” programs such as McAfee or Norton etc.)
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors, prior to installing or reinstalling.
Dec 06, 2007 | Microsoft Office Standard for PC
MS word won't pull up
CLEAN INSTALL needed here.
This is a nice little FREE utility you can try. Install Microsoft "Windows Installer CleanUp Utility"  http://support.microsoft.com/kb/290301/en-us
If you find (PROGRAM NAME) listed just hit the delete button.
Then do the normal uninstall.
Try un-installing again, but this time after the un-install, shut down completely for at least 30 seconds, and then restart.
Then do a search for 'all files and folders' - search for both Office and then  Word, with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those files found.
You should do this search and delete whenever you un-install any programs. It will remove lots and lots of leftover junk files and corrupted files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program. (Do this ESPECIALLY when updating to a NEW anti-virus programs and “Internet Security Suite” programs such as McAfee or Norton etc.)
BEFORE RE-INSTALLING Office or MS Word
Oct 29, 2007 | Microsoft Office Standard for PC
Microsoft Office Professional 2007 Full Version for PC Logo
109 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
