Question about Indesit W 123 Front Load Washer
F 12 Hi, my machine won't turn on. It has electricity but when I press start the led-display goes blank. After a while the sign 'F 12'. Anyone knows what's wrong? Thanks.
    Problem Solver:
  • 15 Answers
Door interlock is faulty.
Posted on Jul 19, 2007
I have a kenmore electric range model #790.9414 and after setting the proper time and hitting start, the time display goes blank after a few seconds and must be restarted.
This is a "feature" imposed upon us by those energy-saving freaks and environmentalist-wackos. What you need to do is press and hold the clock button for 12 to 15 seconds. When you first press this button, the display will appear. Then in about 7 or 8 seconds it will disappear. Keep holding it for 12 to 15 seconds until it re-appears. Now if you release the clock button, it should remain on.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 23, 2014 | Kenmore Kitchen Ranges
My new Kenmore Electric Range, model 790.9419, purchased July 18, 2014...The clock no longer works. I press "clock", the code CLO appears; I set correct time; press START and the display goes blank an
That's an enegy saving "feature" - the ability to turn off the clock. Usually (in most models), you can turn the clock display back on by pressing and holding the clock 10 to 15 seconds.
Sep 17, 2014 | Kitchen Ranges
Intermittent FI (not flashing) on LED display and flashing red light.
Kevin, Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to do When Your Motorcycle Won Start
How to Diagnose Motorcycle Electrical Problems Dennis Kirk Inc
ATV Motorcycle Repair Manuals Repair Manuals Online
Aug 14, 2012 | 2008 Suzuki Boulevard C50T
Power on with fan running fast for 3 seconds, then slowed down but no display and no operation
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Aug 13, 2012 | Computers & Internet
Comunication error
At first turn the machine off, and then press the start button, reverse button and auto lock button at the same time.
-Turn the machine back on while still pushing the three buttons. After the machine has powered on, release the buttons.
-Press the + sign at the bottom of the screen, continue pressing each + sign as it appears. The machine will display a "Test Complete" message, turn off your machine.
-Wait 5 to 10 seconds before powering your machine back on, your machine will run through a diagnostic test and repair any issues it finds.
If this doesn't work;
Have you set up communication is to the "COM Port" designation within Customizer/Digitizer.
Go to >ScanCard >Communication Settings > choose the COM Port you want to use (find out what COM port the cable's using by going to your Start/task Bar in Windows>Control Panel >System >Hardware >Device Manager >Ports (COM & LPT).
There, you should be able to see what port your cable's using.
Hope this helps
Nov 03, 2011 | Janome Memory Craft 9000 Computerized...
My Frigidaire GLFT294OES3 turns on, but after a few seconds, it goes to "No Spin" and errors out. The water won't come through and it just shuts off, please help!!!
To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
You may also have a code such as E47 or E24 etc..
Comme back with the code and I will explain what is the meaning of the code
Oct 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
Washer won't start. Power is on, pressed power, then pressed permanent press, then water temp, then start. There is a red light on spin cycle and it just beeps and doesn't start.
Hi - if that red led light comes on as you press start - then the display module is faulty - however it's not always the case - often its the motor controller module thats faulty..
Your call - display module first and hope it works or controller.
The manufacturers recommended procedure is to replace the display module (primary) if it still doesnt work then replace the control module (secondary).
Cheers
Jun 27, 2011 | Fisher and Paykel GWL11 Top Load Washer
Laptop FTec CL51-15. All of leds (lamp) are on
If you are running Windows XP go to control panel open display go to screen saver tab and click power then go to advanced and configure the power buttons.
Aug 26, 2009 | IBM (250410U) Docking Station for ThinkPad
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Indesit W 123 Front Load Washer Logo
99 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
