Question about Toshiba 61H70 61" Rear Projection Television
Screen seems to flip
Powers up,can see a picture (does not flip) looks like pin cushion,can hear sound,but looks like part of screen does the old style horizontal flipping ,then after being on for a few minutes screen goes black and power light blinks. have done hard reset didnt help,also convergence out of line also.tried to adjust convergence with remote doesnt help.
    Sergeant:
  • 337 Answers
All the symptoms in your tv point to a convergence problem,the unit has 3 amplifiers one for each color,this amplifier IC's need to be replaced and then realign the colors,sometimes just by replacing the Ic's you are able to realign the color with the remote but sometimes they need to be realign from the service menu. You can identify the IC's because they are mounted in heatsinks and by its marking,in the front they have STK--- ---,6 numbers after the letters,their size is about 2.5 " long and 1.5" wide with a row of pins solder to the main board.If you are familiar with tv service this information will help but if you are not too familiar be safe and call for assistance from a servicer.
Posted on Oct 12, 2006
  • Omar Urrutia
    Omar Urrutia Oct 12, 2006
    The rating response is important to the person helping you.
Picture is too large to show on screen
Check its "Pin-cushion" section circuit for the fault. An IC is used there to control the pin cushion distortion. If this IC has got faulty, this type of fault can occur. This is actually a skilled work. If you are not ahndy, seek any technicians' support.
Jun 18, 2012 | Sony KV-36XBR400 36" TV
Screen does not lighy
If you look very closely, is there an extremely dark picture, or a solid black screen? If it's an extremely dark picture, you just need a new backlight. If it's a black screen, you either have a bad connection (broken, shorted or unplugged cable), or need a new LCD. Let me know, and we'll go from there.
Sep 05, 2007 | Cyberhome CH-LDV 712 Portable DVD Player
My LG Super Slim 29"
You don't have a deflection yoke problem, you have a pin cushion problem. Check the pin cushion transistor.
Jul 22, 2011 | NetTV DTV-29XF3 29" TV
My 52 rca screen looks like
This is a pin cushion issue. There should be a setting in the picture menu where you can adjust this. If that does not work than your unit has an issue that you will need a local service center to repair.
Oct 04, 2009 | RCA Televison & Video
Pin cushion adjustment on Toshiba TV 36" CRT
Pin Cushion, someone is pulling your leg.
Oct 26, 2017 | Toshiba 36AF61 36" TV
Vertical pinch on left hand side of crt
You mean the picture on the left side is curved out? Or is it restricted to the very top and very bottom?
If you have the curve problem, look in the menu and see if there is a pincushion control and a pin cushion balance. Adjust the balance until both sides curve the same, then adjust the pin cushion control to remove the curve.
If you are only having the problem in the corners, look in the menu for a corner correction control and play around with it to see if it corrects your problem. If the monitor has no OSD (on-screen-display), then it may be too old to have these controls. You may have to open the unit and see if there are any physical adjustments (little potientiometers). You might want to leave this to someone who knows what they are doing since the high voltage circuit can have 25-35 kV. Considering the price of CRT monitors, you might be able to find a new one for under $50.
Jan 22, 2009 | NEC MultiSync XV17 17" CRT Monitor
PRIMA HT2778P pin-cushioned blue screen - service menu reset needed
Try this one:
1. Unplug your power cord from the box (NOT THE
WALL!)
2. Wait 3-5 min... No more than 5 MIN (very important)
3. Hold down the power and select button at the same time and don’t let go.
4. Have someone plug the power back in… and keep holding the power and select button.
5. Don’t let go until it gets to 0 (it's about 5 min)
6. Once it gets to 0 then it will stop counting down, that when you let go!!
7. Don’t touch anything,
8. The screen will reset and it will go blank. nad that's it
Hope that helps....
Jul 10, 2008 | Televison & Video
TV has audio sound and no picture
major repair; requires 16 pin ic
Apr 19, 2008 | Televison & Video
Loewe TV with pin cushion distortion
Yes if you could give me a model #, it is probably a diode shorted in pincushion area, or a capacitor.
Oct 05, 2007 | Televison & Video
Pt 56tw53 picture trouble
I had the same problem with my TV, It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. $500 with service charges to get it fixed!
Nov 05, 2005 | Panasonic PT-56TW53 56" Rear Projection...
Open Questions:
Toshiba 61h70 Picture Problems Hello, I have a Toshiba 61h70 TheaterView HD Projection TV, and was recently having some slight convergence issues (red was out of alignment and could not be adjusted). So I researched and found that the IC?s (STK392-110) needed to be replaced. I initially purchased them on eBay, to later find out that they were cheap clones and did not work (they made the convergence worse, actually). I then purchased 100% Sanyo IC?s from a reputable dealer and replaced the IC?s again. Once finished, I then entered the service menu and adjusted the convergence alignment. Once the alignment was perfect, I hooked back up the TV antenna, the DVD player (composite), and the S-video from my computer. The convergence is fine, but now I?m having a totally different issue ? the video is ?scrolling?. The menus will show up fine, however any incoming video inputs will show up okay for a split-second, but will then flash and the picture starts to scroll in different directions. This happens with any of the video inputs. I checked and changed all the service menu items to factory defaults, however this had no effect. I have pasted a link below to a short video that illustrates the issue that I?m having. Please note that the video starts off with a black screen, showing the ?input? menu, and then I selected the ?TV input? and changed the channels. You will see the picture fine for a moment when the channel is first changed, but then the picture will start to scroll. Any ideas of what would be causing this? And how can I correct the issue? I?m not a TV repair expert, so I?m not even sure where to start. Any help would be greatly appreciated. http://s75.photobucket.com/albums/i303/hybrydmike/?action=view₪t=TV_Troubles.flv
Feb 27, 2017 | Toshiba 61H70 61" Rear Projection...
Toshiba 61H70 61" Rear Projection Television Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
