Thank you for your post, friend!
From the information you have provided your Frigidaire laundry center is leaking water from the bottom after a day or so. It sounds like you have a slow leak and this could be in your drain line, drain pump, or gasket. I would advise you to review your gasket and drain hose to make sure there is no visible crack or wear that water could be leaking out of. If you do not see any apparent leaks it could be an issue internally and this is not a simply DIY job. You may need to request the assistance of a professional technician for proper disassembly of your laundry center. I hope this information has been helpful. -Matt
Hey Trudy Guldin, thank you for your post!
Based off the information you have provided its sounds like there could be a potential issue within your solenoid, water valve, or water filter of your Frigidaire refrigerator. When was the last time you changed your filter? I would remove and make sure there is no damage visible on your filter. If so, you would need to replace the filter. If it is any one of the other underlying issues I would recommend having a technician come out to the home and properly repair your appliance. -Matt
The water leak becomes significant.
What is my solution?
