Question about Soyo Televison & Video
The colors red and green shifted right
My TV worked fine until 3 days ago. It never runs for more than 1 hour per day as it is in my bedroom. I turned it on and the main picture is correct but the red and green have slid over so now none of the colors are correct. I have tried every button under settings, including factory reset. I know most TVs have that red and green horizontal and vertical setting that can be adjusted, I can't seem to find anything like that on mine. HELP!!!
  • 3 more comments
  • fraukraut Nov 07, 2008
    This tv was also wall mounted by my husband, who is unable to help with fixing due to deployment. I need a way to fix this myself, in other words, simple solutions (if possible)? It weighs a ton, too heavy to take down alone.
    it's more than a green tinge, the colors red and green are both off by about 4 inches. like someone took the picture into two layers and slid the top layer over. the only numbers I am able to find on the back as car as model/serial are
    FMP115MF
    LR2E-32 05FA00043
    it is a SOYO
  • fraukraut Nov 11, 2008
    My TV worked fine until a little over a week ago. It never runs for more than 1 hour per day as it is in my bedroom. I turned it on and the main picture is correct, but now none of the colors are correct. It's like all of the colors have slid off the main picture. I have tried every button under settings, including factory reset. I know most TVs have that red and green horizontal and vertical setting that can be adjusted, I can't seem to find anything like that on mine. This tv was also wall mounted by my husband, who is unable to help with fixing due to deployment. I need a way to fix this myself, in other words, simple solutions (if possible)? It weighs a ton, too heavy to take down alone. It's more than a green tinge problem, the colors are all off by about 4 inches. Like someone took the picture into two layers and slid the top layer over. The only numbers I am able to find on the back as far as model/serial are:
    FMP115MF
    LR2E-32 05FA00043
    This is all for a SOYO tv... HELP!!!
    I also have no user manual, we bought this tv from a friend also in the Military, we have since lost touch.
  • 10,594 Answers
Please mention model and brand of your TV to see its schematics for solution.
Posted on Nov 07, 2008
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Nov 07, 2008
    Please check its user manual and write exact model and brand here as we have seen hundreds of TV model and brands and can't figure out what TV you have. Try to understand.
    The number you provided FMP115MF is wall mount for tv. see it HERE
    Shahid Electronics Nov 11, 2008
    Model number usually written on label at rear of TV sets. Please check model number there and let me know to help you out.
    Do you have basic electronics and little bit TV repair knowledge?
    Description of symptoms shows its failure of electronics parts and tv requires defected parts replacement to present correct colored picture.
    Scholar:
  • 44 Answers
Company name you using????
  • 1 more comment
  • vinodh umaiayar
    vinodh umaiayar Nov 07, 2008
    Hi
    A green tinge can be a tube fault, but if you post the model number of
    the TV someone with a little more knowledge might be able to help.
  • vinodh umaiayar
    The power supply from the amp is acting like a magnet. Try the amp on a
    lower shelf or move it away from the TV to see if the colour staining
    reduces. You'll need to let the set degauss itself. Power off at the
    wall switch for approx 30 mins then switch on. You should hear a sort
    of 'bong' sound as the degaussing coil fires.
  • vinodh umaiayar
    Your CCFL lamp has reached "end-of-life". They go red when they are old.
    You can get replacement lamps here: http://jkllamps.com/index.cfm?action=fam...
    They can also help you with the job, better consult them before ordering anything.
    Good luck
    Sergeant:
    Novelist:
  • 196 Answers
The settings are on the main board the tv needs to be opened to make it clear.
    Top Expert:
  • Soyo Master
  • 77,499 Answers
Unless you are a qualified TV repair person with access to the technical manuals and electronic test equipment for your set you are wasting your effort, this is not an adjustment problem, it is a circuit board failure issue, the cost of repairing these newer sets is so high that replacement is the best option in all but a few cases, go ahead and rate this thanks for trying but the info I have given is correct.
Posted on Nov 11, 2008
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Sony WEGA KV-34XDR960 works all day then about 1 or 2 am it shuts off & standby light blinks 6 or 7 times. I turn it back on but it eventually it shuts off again any where from 5 minutes to a couple of...
U have a thermal/intermittent issue. Given the age of the set and fact that other areas are now going, I think the cost effective way is to replace the set.
May 02, 2017 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
I have a sony projection tv. Colors/piture not right
Replace convergence ICs and a 5 amp pico fuse on power supply. ICs are part number STK392-560.
Just be sure to use thermal paste on the ICs or they will self destruct in a short amount of time.
Jul 06, 2010 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi WD-62827---PICTURE TURNS GREEN
I had the same problem. I deducted that if my TV worked fine for an hour or so and then the colors became bad (green, people's faces purple...), it must be a overheating problem. Simple logic, right? So, I picked up a few tools and a small vaccum and went to work.
I went first for the main source of heat: The lamp. Just a few screws, and I removed it. The lamp cage has a fine screen to prevent the dust to cover the lamp. Mine was covered with dust! And the fan behind the lamp was also covered with dust! Bingo!!! That's my problem! I cleaned everything and vaccumed all the air vents on the the back of the TV. I put the lamp back and checked that the fan was working. The TV works like new since!
Before you are out of a TV for days and spend an arm and a leg for a "Technician" to fix it (replacing expensive parts that didn't need to be replaced in the first place), try what I described above first. It's very simple and it takes only 15 minutes.
Since my TV is 2 1/2 years old, I purchased a replacement lamp. I know that one of these days it will burn out. I'll be ready and my TV will be working again in 15 minutes!
Since my problem was solved, I didn't go to the next step. There must be one or two other cooling fans inside the TV, but they must be working...
Good luck,
alecoz@roadrunner.com
Oct 06, 2008 | Mitsubishi WD-62827 62" Television
Sony kds-r60xbr2 televison
Make sure that you do not have a magnetichc feild around the TV.
Sep 06, 2008 | Sony KDS-R60XBR2 Television
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
Problem with color
Replace convergence STK IC's,then realign to factory spec using service literature fo info.
Sep 29, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
May 21, 2007 | Samsung TXN3275HF 32" TV
Televison & Video Logo
284 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
