Question about JVC AV-27230 27" TV
JVC AV27320 Screen too dark
I have a JVC AV27320 TV that is only few years old. The screen of the set becomes to too dark in recent week. The color is also turning poor, which I don't know if it's caused by lossing the brightness. I have adjusted the Brightness on front panel to max and even adjusted the Screen on the FBT, it didn't help much. Does anyone can help on this set or know where can I get a free diagram for the set. Thank you for your help.
  • 3 more comments
  • Jim huistheman Oct 20, 2006
    Thank you Jomaru,
    The TV is less than three years old and was not used very offen.
    Where can I measure the regulate voltage you mentioned and what could be the possible defective part. I know that I can purchase the service manual on line. However I want to know if there is a site I can find it for free.
    Thank you again for your help.
  • Jim huistheman Oct 25, 2006
    Thank you Techman.
    Please tell me what is the voltage for this CRT heater and which part can be replaced to adjust the voltage. Is there other possible defective parts that can cause this problem?
    Looking forward to hearing from you.
    james15602
  • Dave Mil Dec 31, 2007
    I also have a JVC AV27320 with a lack of brightness, esp. for night scenes. Solution #2 described in this site was the fix. 2 minutes to find a flashlight and phillips and just a very small tweak of the bottom screw and I was back in business. Probably less than 1/12 of a turn if you think of it like a clock. Use the menu function to reset the brightness on the front panel control back to the mid position or slightly below mid position before you make the adjustment. After adjustment, use the brightness menu to run the level up and down scale to make sure you are satisfied with the result, and check with day and night scenes.
  • Anonymous Dec 06, 2008
    Just wanted to say thanks. After two years living with a JVC that was too dark and all the frustration thinking it was a lemon, your simple fix worked fantastic!! Thanks again and happy holidays! :-)
  • jscheffter May 24, 2009
    I had the same problem with my set and was in the same situation as Julip, thought I was going to have to junk it and spend big bucks on one of the new ones. I didn't have to because you guys were there to help. I tried the "Best Solution" as shown in this article and it worked like a champ; my TV is back to normal (before, the screen was very gradually getting darker and darker even though I had the brightness and picture controls maxed out high to compensate). One thing I would mention is that the slots in back are VERY narrow and so you must have a very small Philips head screwdriver to be able to reach the screw inside. As it happened, I did not have one that small but I was able to make do using the smallest Philips head screw tap I had. Thanks again!
Hi solution #2 was correct. the adjustment knobs r on what's called the "flyback" i adjusted the bottom knob and the difference was from "night to day" !!!
Posted on Feb 09, 2008
    President:
  • 3,130 Answers
I think it may be a possibility of low heater voltage. The heaters are the filiments inside the picture tube that gives off the electron emissions that are guided through the tube by the grids and bounch on to the CRT face. If the emissions are low the picture will look all muddy and washed out with poor color. This could be a bad coil or resistor or even a leaky capacitor in the filiment circuit. Although Jomaru could be correct by saying the picture tube is bad also, but I have seen sets that had poor connections in the heater circuits that were condemded for bad CRTs as well. Like he said if you have no TV repair experience, play it safe and call in a tech to assist you in this repair, as there are no user replaceable parts inside this set. A tV set is no place to be experimenting inside if. Good Luck PS please do not forget to rate this thread
Posted on Oct 20, 2006
  • Larry  Dillon
    Larry Dillon Oct 20, 2006
    oops almost forgot There is a AV27260 available for free here http://www.eserviceinfo.com/downloadsm/1... Click on the small red 0 Its not the same model but is almost the same with the same parts inside.
  • Larry  Dillon
    OOps forgot to say, you must download part 1 and part 2 for the service manual to open up propery
Thanks for your help. I was about to trash my TV and buy a new one. You saved me lots of money. I adjusted the brightness on the back and it's like having a new TV. Thanks again
Posted on Jan 01, 2008
Brightness on the JVC AV27320
by rtaylor013 ,Aug 07 '06
Pros: The brightness problem was easy to fix.
Cons: I shouldn't have had to adjust the television in the first place.
I was recently given a JVC AV27320 television by a neighbor that was moving he gave the television to me because it wasn't bright enough. So with a flashlight and a small Phillips screwdriver I adjusted the brightness with the master controls in the back of the set. On the back of the set; the right hand side you will find two vertical slots. The top one is for focus. The bottom one is for picture brightness. With the flashlight I looked into the slots located the place for the Phillips and adjusted the brightness. Simple I know but not all fixes are hard.
Posted on Dec 17, 2007
I was NOT electrocuted! I took the advice proffered by Dave Mil. IT WORKED!!!! Took about 30 seconds. I'm a 72 yr. old widder woman who's been suffering for over 3 years with this DARK pix. If there was a night scene in a good movie-I'd have to go to another tv. This condition was extant from the day of purchase! Many thanks to Dave & the TEAM for this great site!
Posted on Feb 21, 2008
    Sergeant:
  • 337 Answers
If your tv is older than 5 years it qualifies for a possible bad picture tube but it can also have a regulation problem in the power supply making all the voltages supplies lower than normal,specially the volts supply to the horizontal output transistor,he energizes a transformer that produces the high voltage that lights up the picture tube.You can purchase a service manual at http://www.servicemanuals.net/ ,you can also check your local library,in big cities some libraries have squematics.If you need more information please let Us know.
Posted on Oct 12, 2006
  • Omar Urrutia
    Omar Urrutia Oct 12, 2006
    The rating response is important to the person helping you.
  • Joseph F. Feb 28, 2013
    Thanks.I have been living with a really dark picture.This worked.Thanks.Joe F.
SOURCE:
I have a JVC model AV27320 standard TV. The picture is dark and the tint is off. The colors you can see are blue and red. Tried adjusting tint and brightness from the menu and no significant change. ...
It is one of two things the picture tube is bad and the green emission is very low or the green gun is open, the second possibility is the video driver or output is shorted on the video board "plugged in the back of the picture tube"
Mar 03, 2011 | JVC Televison & Video
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2011 | Toshiba 65H82 65" Rear Projection...
Picture has become progressively dark 27'' TV JVC AV-27320
disgaussing will not help this problem..i am scared your picture tube problem or try to change the crt socket first it is not cost much
Jul 01, 2009 | Televison & Video
Dark picture on 62" lcd
how old is the lamp , if is about a year old need a newone
May 12, 2009 | JVC HD-61Z575 61" Rear Projection...
TCL TV picture too dark
try turning the light sensor off
Oct 20, 2008 | JVC AV32F476 32" TV
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
The picture on my JVC TV is too dark
On the inside of the TV, on the flyback transformer there should be two controls. Turn the one that says "screen" very slowly clockwise while looking at the pix. The pix should get brighter as you turn it up- if you go to far you will see lines in the pix or the TV may shutdown.
Aug 30, 2007 | Televison & Video
Rear projection dark picture
Open up the front of the set and find the screen controls and perform a grey scal alighnment by adjusting the red , blue , and green screen controls but be carefull and make sure you adjust them evenly or the picture will not look right. Good Luck
Mar 23, 2007 | JVC AV-56WP30 56" Rear Projection...
Horizontal Lines
The unit most likely has a short in the horizontal section and would require repair by a service center. Go here to find a JVC repair center in your area http://maps.jvc.com/cAscList/
Sep 18, 2006 | JVC AV-56WP74 56" Rear Projection...
JVC AV-27230 27" TV Logo
4,816 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
