Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880 Logo
A
Anonymous Posted on Mar 21, 2012
Wiring diagram for t30 model 2475 ingersol rand compressor
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
Need to remove t30 2475 pump pully
Hi Mike,
Your problem is very simple please do he following.
1. Remove V-belt.
2. Loosen the lock nut of the compressor pulley.
3. Use a 3 jaw puller to pull-out the pulley.
3. Slowly tighten the puller and thats it.
Hope i can help in your problem,.
How to wire a t30 1 phase 230 volt in control box, they used white black green, are the white and black both line voltage for 230 volts? its a model 2475
yes white and black are both line voltage in.each wire will have 110 to 120 volts. Attach one wire to top of starter contactor left side the other to top of starter contactor right side. Attach green wire to ground.
I believe that the motor starter circuit on my Ingersoll Rand 2475 5 hp 80 gallon compressor is incorrect. It's a 30 amp single phase compressor
You should not be pulling over 30 amps. If you are you may have low voltage, incorrect wire size or to long of a run for wire size. I would use a hand held meter and check the amps at full load.
1helpful
I have a ingersoll rand type-30,model#2475 7.5 hp,3 phase.need a wire diagram or how do you wire up the low oil and pressure switch? this is a used compressor with wiring still conected, has 3 leads to the...
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
2helpful
Correct rotation of copressor
Checked all the IR compressors in stock and all turn counter-clockwise facing pulley, however you could check the pump for fan angle on pulley. The fan on the compressor pulley blows air towards the pump. Generally, pumps turn CC because that would allow for the use of gasoline engines which all turn CC. Please email you questions, and Good Luck.
Top Ingersoll Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
