Question about HP PSC 1315 All-In-One InkJet Printer
Error and no start
I replace the USB device, and take apart the carring system. Then, when I rebuilt againg,.. the machine dont work. I need reset the software or not?
Why dont work well if I dont break any mechanical parts?
Why dont advanced to exactly point to work again?
Thanks
  • 322 Answers
No you dont need to reset it, it may be that you forgot to install the sensor ribbon on the carring assembly, it senses where the carring sistem is in reference for printing. If you installed it it may be backwards and it is not sensing.
Posted on Nov 25, 2008
Toyota 4runner problems
check for an over heating situation with the motor as what you say indicates engine over heating.
Jan 23, 2014 | Cars & Trucks
Image runner c5870 error E0008-0001. How can i solve this problem?
that error happend because the last time the fixing assembly was rebuilt and or replaced the counter wasn't reset. what you need to do is go into service mode and clear the counter for the upper fixing roller and lower fixing roller.
to get into service mode you need to hit the additional functions key
the 2&8 at the same time
then the additional functions key again
this should get you in service mode even though there is an error code....if it doesn work the first time you try it shut the machine off and turn it back and try again. once into service mode
you need to hit the copier button....
then go across to the last tab .....counters...
click on it then click on drbl-1
then you will scroll down till you see
fx-up-rl click on it then hit the C button on the control panel where the numbers are and it should reset it back to 0
and then you need to click on
fx-lw-rl and do the same with it
fx-ex-rl and clear it as well
then you should be able to turn the machine on and off and it will come back to life
Jun 19, 2010 | Office Equipment & Supplies
94 ford tbird rebuilt engine wiring harness plug too small
If the rebuilt motor is a twin of the original,use the original wire harness. Why would the motor have a harness on it?You usually keep everything,including your intake system and just get the long block.
Mar 09, 2010 | Ford Thunderbird Cars & Trucks
Sharp copier ar-m236 error h4-21
try to reset by programming...here u just do ..p * c * (p star c star ) u will go in simulation mode .then press 14 ,start .mechine will ask you yes or no ? u just press 1 for yes .and press start ...your mechine will work..if same problem prsist try to check fusing unit...dont forget to thanks to me
Dec 28, 2009 | Sharp AR-M237 Copier
Printer-Genicom 2280+ Printer stopped then continued working, often on LCD Hardware error. When turn on printer- on LCD AGA Error.
The AGA Error on the 2280+ indicates the Automatic Gap adjust is not working.
This may be caused buy;
An obstruction (eg paper jam, ribbon etc) preventing the AGA from working correctly.
The AGA flag becoming detached from the printer or damaged
An incorrectly fitted print head
Fault AGA sensor.
You can overcome the AGA error by disabling the AGA and manually setting the print had gap.
To disable the AGA
Power the pritner on holding down ONLINE, keep ONLINE held down whilst the printer initializes.
When the printer displays ASCII80 ASCII136 release ONLINE
Press NEXT until you see AGA
Select AGA and set this to OFF
You can then manually adjust the print head gap in the normal menu.
Menu>Adjust>Head change the value to increase or decrease the head gap as required.
Jul 21, 2009 | Tally Matrix T2280 Printer
Usb device error
The cord might likely the problem. The iDA-X100 will only recognize iPods if you use an original Alpine USB cord. Using any other cable won't work. I had this problem when my Alpine cable fell apart and stopped working. I thought any other cable would work, but that's not the case.
Jul 06, 2009 | Alpine iDA-X100 Car CD/ MP3 Player
Audio device don't work
hi,
please download and install microsoft UAA driver after downloading it then install your audio driver.
May 29, 2009 | Panasonic Toughbook 50 Notebook
" USB ERROR "
Hello kenwood12312,
With the receiver OFF, remove the USB device then turn the power ON. If the same display is repeated, use another USB device. Remove the USB device without entering the remove mode. If this does not work, try resetting the receiver. Press the "reset" button just above the AUX INPUT. This will return the unit to factory default settings. If these steps fail and you still get the USB error, the receiver is faulty and needs service.
Hope this helps.
May 20, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Need help
Is error happens mostly when usb devices or diskettes is inserted to the computer.. The computer tries to boot from them but when there isn't any boot data it just keeps making that error..
Just try to remove all extra usb-devices, cd's/dvd's and floppies/diskettes connected to the computer, so it's only monitor, power, mouse, keyboard and internet that is plugged in..
PS: Please rate this solution
Mar 11, 2009 | Ulead Videostudio 8 for PC
Kenwood KDC-MP438U "USB ERROR"
IF YOU DID NOT PRESS THE RESET BUTTON NEX TO THE USB PLUG, DO IT. IT WILL REINITIATE THE DEVICE TO THE FACTORY; YOU WILL HAVE TO ADJUST THE CLOCK.
I DID BECAUSE IT WAS WORKING AT FIRST.( PAGE 3 OF THE MANUAL)
CLAUDE
Dec 20, 2008 | Kenwood KDC-MP228 CD Player
HP PSC 1315 All-In-One InkJet Printer Logo
53 people viewed this question
Ben Johnson
