Question about Sony PCS-TL50 (PCSTL50) Wireless Video Conference
Dial Problems
Dear reader, I have set up 2 VC systems via LAN (G70 & TL50).There are no firewall implications.I am able to call From the G70 to the TL50 , But I am not able to call the G70 from the TL50 . The error message "your systems attempts to connect to other equipment that a video conference system" appears. I am able to ping both ip adresses. Regards Emile
SOURCE:
SOURCE: Will not detect
Ok well all I can suggest is this... first try a NON-crossover cable.. 2nd.. try the address of 10.1.1.1 The server should be setup according to the manual.. and should be detected upon connection, Also is the server to be set up to ASSIGN an address via it's DCHP or to RECIEVE one from ya lappy? I mean basically it is just a network device that sends stuff when asked, not unlike a networked Hard Drive etc. Usually ya set up the lappy for DHCP and the Video Server gets it's address from the lappy, & when "Polled" sends data to whomever "Polled" it.
Posted on Aug 03, 2007
  • 5 Answers
SOURCE: Internet connection failed but IP address obtained.
Hi, i had the same problem but it was fixed by simply re directing my ISP's DNS settings away from Sony's. manually change your DNS settings to the ones below and it should work fine !
  • 208.67.222.222
  • 208.67.220.220
  • Posted on Nov 25, 2007
    SOURCE: set up Sony Wega TV on Video 2 for a Wii system
    In the set up screen: Video reset ports and activated them individually to allow the TV to recognize the game and the DVD players...
    Posted on Dec 28, 2008
    • 50 Answers
    SOURCE: dial up (3g dongle) internet (lan) sharing on vista
    the ps network will not recognize dial up.. you need to update to broadband... sorry
    please rate me...thanks
    Posted on Jan 12, 2009
    SpideRaY
    • 687 Answers
    SOURCE: My PS3 is telling me that it
    This sounds like you might need to open a port on your router or firewall to allow the PS3 to send info to the games specific server just because the PS3 has been given an IP address the PS3 still needs to connect through your router using NAT.
    I suggest first turning off your Windows Firewall and your ISP firewall then into your router admin panel and open up the correct port then do the same on your firewalls.
    Next, you need to enter these numbers for the PS3 to work.. so put these in the port start and end. 80 , 443 , 5223 , 10070 (start) and 10080 (end) , 3478 , 3479 , 3658 , 10070. They should be in both start and end except for the fourth which will have 10070 in start and 10080 in end.
    The first 4 are TCP and the last 4 are UDP both types are required.
    Posted on Feb 01, 2010
    Can't get connected to internet.
    Hi, you can try to renew the network driver from here:
    http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_P4_9400&os=WW1&osl=en&catid=&impid=
    The driver has to be unziped before installation.
    Check also your internet connection for fault wireless or lan.
    Are the router or dial up set to on ?
    Check also firewall and antivirus settings.
    If you are useing dial up connection check for fault.
    Hope this will help you.
    Aug 17, 2011 | Dell Inspiron E1705, Intel Core 2 Duo...
    Solution of error with yahoo 81003016
    Click Messenger tab. Make sure the program window is open.
    Then, click Connection Preferences. It will open up a window for you to work on setting up your connection.
    On the Connection options, you can either choose:
    1. Connect directly to the internet. (This is the recommended setting if you never had connection problems.)
    2. Connect via a proxy server. (Use this option if you are behind a firewall and know your proxy server settings.
    From the Internet connection option, you can choose among these three–Dial-Up, Broadband (DSL/Cable) or High-speed (T1/LAN). Once you’re able to select all your options, click Apply then click OK.
    You may try switching connection from Connect directly to the internet to Connect via a Proxy Server and choosing HTTP Proxy then click Apply. This should work for you.
    Good luck.
    Jun 25, 2010 | Microsoft Windows XP Professional With...
    How to turn on wireless LAN for HP G70
    If the wireless receiver is disabled just go to Control paned--system--device manager -- then right click on the wireless card and select enable.
    Feb 26, 2010 | HP G70-250us Notebook
    Acer Aspire One Netbook wireless internet connectivity problem
    Try Resetting Your Wireless Router.. turn it off then back on
    then run a repair on your wireless network
    Nov 15, 2009 | Acer Aspire One AOA110-1113 Netbook
    Login error 81003004 from Yahoo Messenger
    as far as wat i did to my YM.
    i simply checked the connection preferences and turned
    "Connect via a proxy server."
    then select
    "HTTP proxy"
    after that take a look at your internet connection dropdown list..
    some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself..
    hope that helps ya ^^
    Dec 16, 2008 | Yahoo Messenger
    Error code 80048820
    MSN Message error 80048820, unable to signin
    Problems:
    - While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
    - Unable to Sing in
    Probably reasons-
    - Your system time/date incorrect
    - Internet Proxy setting incorrect
    - softpub.dll disable/missing
    - Firewall does not allow to access, etc.
    Solution-
    Step#1
    - Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
    - Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
    Step#2
    - Correct the computer system's Time/Day as current (if required).
    Step#3
    - Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
    Step#4
    - Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
    Reference from:
    http://www.trulybangladesh.com/itnews.php
    Aug 12, 2008 | Computers & Internet
    Westell 327W (Versalink)
    you want to setup a peer to peer network using a workgroup. File sharing must be enabled in XP and Vista in order to share files. Temporarily disable the firewalls in Windows when setting up the shares....search on the Internet for setting up a Workgroup in XP
    Jul 01, 2008 | Westell Wirespeed VersaLink...
    Wi Fi fine, ISP fine, no internet via LAN connection though.
    Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
    Jan 21, 2008 | NetGear DG834G Router
    No more internet
    This error may be caused by the WINDOWS FIREWALL being set to prevent incoming and/or outgoing communications on the dial-up connection.
    To test if this is the case:
    Go to CONTROL PANEL -> Windows Firewall; turn the firewall OFF and see if the error disappears.
    If the error disappears, turn the Windows Firewall back ON, and check the settings in the Exceptions tab, and the Advanced tab -> for the dial-up connection. If you cannot locate the bad entry, you can try the 'Restore Defaults' button in the advanced tab (which may produce other undesirable problems depending upon your configuration and software you've added).
    Jan 13, 2008 | E-Machines Emachine T5026 power supply **...
    Sony PCS-TL50 (PCSTL50) Wireless Video Conference Logo
    Top Sony Computers & Internet Experts
    Alun Cox
    Steve Allison
    Steve Allison
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
