Question about Electrolux 23 in. ESL624 Built-in Dishwasher
Electrolux esl 6251 built in dishwasher 2 years old
Flashing code 20 which says problem with water outlet
have pulled it all out, wont drain
have been able to drain it manually, outlet pipe looks clear
now what??!!
  • damianyoung Feb 15, 2009
    Numbers flashing and has tripped the fuse a few times
PROGRAM WONT RESPOND MACHINE NOT STARTING
Posted on Apr 11, 2009
What is the meaning of a flashing cf code?
Electrolux support site doesn't show a "CF" code. "PF" is Power interruption.
http://www.electrolux.com.au/support/troubleshooter/
Jun 03, 2015 | Electrolux 24 in. EDW5505EPS Stainless...
Hi wont start. just making a loud whiring noise.
According to your description of the fault, something was blocking drain turbine of main motor. Dishwashers always first start drain water because calibration of water level inside dishwasher (empty). In your case, the main motor is same motor for washing and draining. Runing in one direction means washing, runing to oposite side means draining.
The solution is to open a turbine pump and remove all obstacles and visual check turbine impeller,ceramic seal and plastic sleeve on the motor shaft.
Dado
Mar 26, 2015 | Electrolux Dishwashers
When i turn the dishwasher on nothing happens at all.
wait 15-20 minutes and see if it starts - chances are it's "warming" up, or trying to drain old water.
Mar 14, 2011 | Electrolux 23 in. ESL6114 Built-in...
Electrolux error code 1, how to reset.
Also got error code 01. Unplugged dishwasher, turned off water supply, disconnected water supply line at sink so it had slack to pull dishwasher out of built-in space, removed two wood screws holding dishwasher to counter, pulled it out onto floor, put it on blocks as reader suggested, tilted to side 45 degrees, water drained out onto rags. Then restored to upright, restored supply line and opened valve at sink, plugged back in, unit automatically reset, returned to built-in, reinstalled screws to counter. Worked like a charm. Took more time to read everyone's advice than to do the job (about 30 min.). Thanks.
May 20, 2010 | Dishwashers
DISHWASHER BEEPS AND DISPLAY FLASHES 20 ON SCREEN ELECTROLUX EX302 DISHWASHER
i have just fix my one it was the drain pipe on the sink was blocked (where the pipe from the dishwasher join on to the sink pipe) pull the pipe of and should see what is there BUT BE WARE OF WATER STILL IN THE DISHWASHER DOES NOT COME OUT WHEN YOU PULL THE HOSE OFF ) hope this help
Michael
Jan 16, 2010 | Electrolux Dishwashers
Electrolux dishwasher shows code 10 not filling fault and code 20 not draining fault but when running you are able to hear it filling and draining. Whats the problem.?
I had the same issue (Electrolux ESF 6251). I had both error codes 10 and 30. I found that the short hose connecting the inlet valve (solenoid) to the tank was cracked. That explained error code 30, but even after replacing the hose I still got error code 10. I checked water supply and also drain hose and filters. I realized that I had recently tried to flush out lime scale and suspect that the drain or pump had lines could have clogged up. I tried pumping into the floor drain inside the dishwasher (removed the filter cartridge and screen) simply with a suction cup like you use in the kitchen sink. Voila. Now it works again...
Sep 17, 2009 | Electrolux Dishwashers
Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
Electrolux 23 in. ESL624 Built-in Dishwasher Logo
908 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
