Question about HP Business Notebook 530
Baterry Backup only rest for 10 minutes
When i uses the Laptop plugging in the Charger it works fine but when i work with out Charger with full charged baterry the Back rest up hardly for 10 minutes ,earlier it was not so the baterry back up was there for atleast an hour.the laptop was purchased in January 08.
  • HP Master
  • 1,250 Answers
Its better take your laptop to the service centrel and complain about the battery status there, because your laptop is still under warranty, its better to avail the warranty
Posted on Nov 06, 2008
Laptop is not turning on after I change my laptop charger. I remove the battery and plug in my new charger it works fine but suddenly shut off. I put the battery back and plug the charger in. No good.
You need to check the charger, I do not think it is any good as the charging power is in the charger unit not the computer. It sounds as if the battery in the computer is totally dead and that is why it shut down. Hope this helps.
Sep 15, 2015 | Computers & Internet
Extending the life of your laptop battery
Laptop battery can only last for sometime. The only thing you can do is maybe extending it for a little more time. This is true for all types of battery - high-end Lithium-ion, NickelCadmium (NiCad) or nickel-metal hydride (NiMH) and basically for all brands of laptops and netbooks (Acer, HP - Hewlette-Packard, Dell, Gateway, MSI, Asus).
Some ways to extend the life of your laptop battery:
- good practice of using the original or right charger and the right specifications
- a regular dose of full-discharge and recharge, maybe once a week is recommended.
- It's also a good practice to avoid direct heat or exposing your battery to sunlight. It will be of help if you use a laptop cooler. Laptop cooler will significantly lower down the temperature at the back of your laptop, avoiding heat for your devices - hard disk, memory modules, processor and also for your laptop battery. You can notice this by yourself. Turn on your laptop for a 5 to 10 minutes. Feel the back of your laptop. Now, install your laptop cooler and feel again the back of you laptop after ten minutes. Notice a significant difference in the temperature?
- If you are using your laptop for a long period of time, for an 8-hour office work, it's good if you fully charged your battery and then remove it from your laptop (see proper instruction on removing the battery). Next is to connect your laptop to your adapter and continue with your usual work. This will give you laptop battery a needed rest. You can adjust your power setting for your laptop to hibernate once you closed the lid of your laptop. This will ensure that you still save you current working environment if you wanted to also take a rest.
on Sep 12, 2010 | Computers & Internet
I am not getting any power to the laptop i have the battery disengage from the laptop with direct power it is still not comming on
you need to put the baterry back on if the battery is bad replace it, the charger is for the baterry. a laptop needs a battery to work, the power that is coming out of the charger only charges the battery it isnt going to power on the pc, it is for maintaning the proper voltage in the battery.
Jun 03, 2010 | E-Machines M2105 Notebook
Targus COMPACT laptop charger isn't working
Your battery sounds like its buggered. I would suggest buying a new battery
May 20, 2010 | Lenovo 3000 G530 Notebook
Laptop is getting heated very quickly and it is not even giving any backup charging
Try getting a portable laptop cooling system. They're about $10 on Amazon. Simply plug it in to your USB and rest your laptop on the pad. That should keep it cool. If you can't get a cooling pad, try getting two solid pieces of some (wood can work fine) and put one on either side under the laptop. Keep it elevated but away from the heating vent. This way, it's above the surface and the laptop may stay a bit cooler.
For the backup charging problem, you may need a new charger or computer battery. If the battery isn't charging, that means it dead.
Feb 28, 2010 | Toshiba Satellite A100-S8111TD Notebook
My acer d250 laptop wont turn on unless it is plugged in
Clean the baterry connector port with an alcohol solution or Spirit solution.and try.
If you can get hand to another battery,check out if everything is fine.Otherwise replace the battery.
Check if you have warranty of the battery.
Dec 27, 2009 | Acer Aspire One PC Notebook
i suggest too use whitout the battery when is full because the more you use to more you decrease the life time of your battery and that's a fact.
Dec 04, 2009 | Computers & Internet
IBookG4 shuts down un-expectantly w/ battery fully charged
your having an overheating problem its either your processor or your chipset inside the laptop..let it rest for a while put a cooler pad under your laptop while using it to prevent further damage..i suggest you backup all your data also before it crashes permanently..also bring it to your nearest mac service center...hope this helps
Aug 31, 2009 | Apple iBook G4 Mac Notebook
The battery does not charge anymore ,the bios setting says idle
remove battery and reseat.
Use VOM (Volt-Ohm Meter) and phsically check to make sure the power supply is putting out advertised voltage (typically 19-20 VDC)
Make sure power supply recepticle (the female part on the laptop itself) has not been broken or reamed out such that contact is not being made.
When you plug power supply in, does the charging light on the laptop come on?
Mar 07, 2009 | Dell Latitude D600 Notebook
Acer 1690 freezes when plugged into wall adapter
Battery has gone bad. Replace the battery.
Feb 26, 2009 | Acer Aspire 1690 Notebook
HP Business Notebook 530 Logo
87 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
