I bought a new 1394 (Firewire) and cannot get my IBM laptop with, 1394 4 pin port, to recognise my Canon ZR850 camcorder. When I connect them and turn on the camcorder nothing happens. Any suggestions please?
  • 1,250 Answers
Check the driver status of the firewall port of your laptop, also check while connecting your camcorder to the laptop, the connection setting of the camcorder
Posted on Nov 06, 2008
I dnt hav usb cable for my handy cam DCR-HC52E ...
Product Summary
    4-pin to 4-pin IEEE 1394 iLink FireWire Cable dv out to laptop Connect and transfer home movie from your digital camcorder to Notebook computer.
    You will need a Firewire port on your computer, also known as a DV port or IEEE 1394, to use this cable. This is NOT a USB cable.
    This DV cable will connect your laptop (notebook)
    NOTE: for some models, becuase of no DV jack on the body, this cable connects to docking station/cradle instead of connecting directly to your camcorder.
Mar 20, 2011 | Sony DCR-HC52E Mini DV Camcorder
Hello, My laptop does not have a firewire port. What do I have to do to transfer video to my laptop from my GL2?
What brand and model is your laptop?
Since we don't know the laptop model I have to cover a little more info here.
Most laptops have at least 1 expansion ports available on the side and you can use that to add additional ports or features if needed such as Firewire, USB2.0, or Ethernet, etc
Older laptops came with 1 or 2 full size PCMCIA ports. Those are rarely used anymore.
Newer laptops usually have an ExpressCard port.
These newer cards come with either 54 or 34 pins so you'd need to get the right one for your laptop.
For example, view the main ExpressCard info here
Be aware that Firewire is officially known as the "IEEE1394" protocol. So some sites may refer to it with that name and it's the same thing. Apple calls it Firewire and Sony calls it iLink.
There are several different pin configurations for firewire.
Original 400Mbps speed Firewire from 1995 has a mini 4 pin or a full size 6 pin cable.
Newer Firewire 800 has 800Mbps speed and is called 1394b.
That has it's own cable connector as well and is not very common. It's much faster than USB (even Firewire 400 is ) but it didn't get used a lot.
The firewire connector s are visible here:
The Canon GL2 uses the original 400Mbps 1394 protocol but the connector might be proprietary since it appears to have 5 pins.
It's visible here from the user manual.
There are 6-pin sockets and smaller (non-powered) 4 pin sockets and they are both still "firewire" but the small one has less options since it has no power connections with it. So the small connections can send data but can't run a portable hard drive or anything that needs power.
The small connectors are used for laptop ports and camcorders while full size desktops usually have the full size 6 pin ports. So to connect the 2 they make adapter cables with one of each type on each end.
Such as this one:
That fits most applications but I think the Canon cable is proprietary, so hopefully you have the original cable.
You probably need a laptop 1393 DV expansion card, DV editing software and the right cable. The socket on the GL2 doesn't look like a typical IEEE connector in the user manual so that may be Canon specific. If you still have the original cable that came with it then you're all set.
You can find a laptop expansion card online such as doing a search on with the words expresscard + 1394 and you will see many ExpressCard adapters to pick from.
Get the laptop 1394 expansion card that matches your Canon Cable and that can plug into your laptop on the other end (choose the right 54 or 34 pin type) that matches your laptop.
Jul 25, 2010 | Canon GL2 Mini DV Digital Camcorder
I have new emachine laptop . I bought a usb cable with firewire-1394-4 pin to download from my gr-d240 camcorder . But laptop does not accept/recognise it ...usb is only connection on laptop
Ok, so the cam accepts firewire but the laptop doesint, you would need an add-on card, unless your laptop has firewire already, like that one if it does have one then you will just need to connect it in and install the drivers and software included with the cam i hope it helps
Dec 31, 2008 | Computers & Internet
Unknown device
1394 PIN is device found therefore it needs drivers. Firewire drivers u can get free with this link
Jul 28, 2008 | Panasonic PV-GS65 Mini DV Digital...
NOt recognized
if your trying to download video usb won't work! must use firewire cable hooked up to dv port on cam and connection on laptop or tower called 1394-cable is either 4 pin or 6 pin-depends on computer- cam is always 4 pin-says dv on camcorder-usb only for still pics-use windows movie maker in xp or vista to edit
Jun 28, 2008 | Canon MV700 Mini DV Digital Camcorder
Canon MV800 - FireWire connection
firewire is also called 1394 or dv port-card can always be added to older computer to support-cables are 4 pin to 4 pin or 4-6 pin-cam is always 4 pin -mac and most towers 6 pin-laptops are 4 pin-look for a port that looks like usb but has a trapezoid shape end
May 22, 2008 | Canon MV800i Mini DV Digital Camcorder
MY IEEE 1394 port does not recognise camcoder
Although this post is rather old, I can tell you that the mini 4-pin firewire port is the bane of my existence. The 6-pin port is made rather sturdy with heavily shielded cable. The 4-pin uses the same heavy cable, but does not have the strength to support the cable, if it happens to droop. This causes pins to get slightly bent out of alignment, and upon re-insertion, you can get crushed pins if you are not VERY careful. Examine both your cable end and the port on your camera/deck - you will probably find one or more of the pins have been pushed back. Pray that it's the cable that's dead, and not the port in your camera/deck. I have a Canon XL1 and a Sony DSR-40 with the same problem - crushed pin in the unit's port. I'll have to spend $$$ to get these ports replaced.
May 17, 2008 | Panasonic AG-185 Camcorder
Canon ZR800 MimiDV Camcorder
You cannot connect a DV cable to a USB port. These are two incompatible standards. DV is also called Firewire, iLink or IEEE1394. You PC must have that kind of port for you to transfer your video from the ZR800 and you will need a DV (iLink/Firewire) cable. You cannot use USB cable they will not work. Check if you want an example. Most new PC come with 1 or 2 iLink/Firewire/1394 port. If you PC does not have an iLink/Firewire/1394 port then you will need to install a iLink/Firewire/1394 card (see for more information.
Aug 13, 2007 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR 850
I did try the windows movie maker soluction but it still is saying no camera
Jun 01, 2007 | Canon ZR850 Mini DV Digital Camcorder
Saving Dv tape to computer? Getting computer to see camera?
The USB connection is for getting still images (photos) off the camcorder. To get moving images (video) off the camcorder, you must use a FireWire cable (IEEE 1394). The cable only costs about $15. But you need to have a FireWire port on your computer to plug it into -- if you don't have one, you'll have to install a FireWire card. Check someplace like TigerDirect computer parts supplier, they are only $15 to $60 now.
Or, if you don't want to open up your computer to install a FireWire card, you can buy a Pinnacle MovieBox for $120. It just sits next to your computer, not inside. It is very easy to use and comes with great video editing software. You plug the FireWire from your camcorder into the front of the MovieBox, then plug the back of the MovieBox into your computer with USB.
Plus, you can use the MovieBox to record from your VCR or DVD player into your computer! For that, you'll need the standard red/white/yellow cables.
In fact, if your camcorder has those cables, you can use them to go thru the MovieBox, and save yourself the cost of the FireWire cable. But I think FireWire will give better quality than the red/white/yellow cable.
Sep 25, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
