Rank: Wiz
Rating: 77%, 876 votes
Sounds like the battery died. This may have happened because the AC Adapter was not properly charging the battery. To see if a faulty AC adapter is the cause, check the following:
1) Is the indicator light on the AC adapter on? Most AC Adaptors have one.
2) Is the indicator light on the laptop on notifying that the battery is charging while plugged into the AC adapter?
Try to borrow an AC Adapter from some one who has the same model laptop that you have. It is VERY IMPORTANT to get an AC Adapter with the same voltage and amperage ratings as your current AC Adapter. If not, yo urun the risk of damaging the electronics.
If you do not have a spare, there are sever web sites that sell AC Adapters.
http://store.comptick.com/brands-abit.ht...http://www.laptoptravel.com//AdapterSele...These appear to be the requirements of the AC Adapter. Double check these with what appears on the AC Adapter.
Input: 110-240V 50/60Hz Auto-Detect International Compatible
Output: 19V - 20V DC, up to 90W max
If you are unable to find what you are looking for on the sites above, you can readily find what you want on ebay as well.
