Question about Barska Optics Barska 10-40x50 Ir Swat Tactical Riflescope Ac10550
Recoil from 300WSM
Thinking about purchasing 10-40X50 IR swat.
Will it handle the recoil from a 300WSM on a remington 700 no muzzle brake,with out voiding the warranty.
    Problem Solver:
  • 8 Answers
Well, it Barska says it's .50 cal proofed, whatever that means. One would presume it could take 30 magnum recoil then.
On the other hand, Barska is a low end quality manufacturer. You cannot expect durability in a low end scope. Of course, you could get lucky.
Unless you're target shooting at an immovable object, 10x - 40x is much more power than you'll ever be able to use. You're much, much better off considering a 4x - 16, for instance, in a higher end scope line than this scope.
Consider that at 40x the exit pupil would only be 1.25 which would make even the highest quality scopes quite dim. Barska won't have be best glass in the world and so would probably be unusable beyond some level like 18x unless in very favorable conditions anyway.
The problem with heavy recoilers and scopes is that the heavier the scope the more likely it is to take damage due to recoil. It's because it hangs out there on those high scope rings, and is heavy.
Posted on Nov 26, 2008
Coleman powermate vangaurd 9hp. how long is the pull start rope?
no set length on any recoil repair
old one will be stretched or broken
melt cord end for ease of fitting and no fraying through holes
and finishing knots
feed one end into recoil internal through outer and inner casing
then knot
set recoil spring into correct position and tension
cord is at least three times around recoil
leave excess cord out for pull handle and later adjustment
then cut .. melt end .. feed thought pull handle
then adjust as you test recoil off the motor
then fit to motor.. pull a few times
and final adjustment of cord length at the pull handle
Oct 13, 2016 | Coleman Electrical Supplies
How do I remove the centrifugal clutch so I can access to broken recoil on a Remington rm2599 gas pole saw
A lawnmower flywheel puller is the cheapest and easiest way to get it off, but if for some reason it doesn't fit, a two or three prong puller is the best way to remove the clutch. You can usually borrow one at your local chain auto parts store. The lawnmower puller threads into the bolt hole and the nut on the shaft is tightened until the clutch pops loose. I personally prefer this method since there is no chance of distorting the clutch housing.
Nov 03, 2014 | Garden
How to remove/replace the recoil pad from a Remington 700 CDL refile?
There are two slits in the pad over the two mounting screws. Most are phillips head screws so put a dab of grease on the screwdriver and simply take it off.
Oct 17, 2014 | Remington 700 CDL, .243 Win
How can i tell how old my remington model 1100 is
Hi tommyw57
You will never find a recoil pad made just for the 1100 unless you buy one from a gun show that came off of an 1100.
Go to Walmart and pickup the recoil pad of your choice, install it on your 1100 and draw the outline of the stock on the oversized recoil pad.
Remove the pad from the gun and on a grinder, reduce the size of the recoil pad down to the size that fits the stock of the 1100 that you drew on the oversized recoil pad.
Please take time to rate me
Oct 31, 2012 | Garden
Pullstart cable broke
Remove nuts mounting recoil assembly. Observe how rope is wound around pulley. Find end knot in pulley wheel. Cutoff end knot and remove old rope. Find end knot in handle, use needle nose pliers pull thru old rope. Rope is sold by the foot at mower repair shops. Replace rope as observed before removal. Cut to size after wrapping recoil assembly and attaching thru handle at proper length if at recoil assembly or on mower handle. Ensure good knot in hole of recoil assembly and handle.
Sep 22, 2012 | Toro Power Lawn Mower
Broken pull chord
Remove recoil assembly from top of engine. Observe recoil wheel and find knotted end of rope in wheel, Observe direction of rope wrapped around wheel, cut knot off wheel end of rope remove rope. Rope purchased by the foot at mower repair shop. Feed new rope end into hole in recoil wheel wrap around in correct direction, feed rope thru recoil cover, remove old rope from handle, feed new rope thru handle to proper length, Knot rope to stay in handle.
May 14, 2012 | Toro Power Lawn Mower
Recoil starter wont let me pull it out
I would think that your engine control cable has gone bad. There is a brake on your flywheel and your engine control cable releases this brake, this cable is hooked to the handle that you have to hold down to start the engine. you can remove the engine cover and see the brake against the flywheel, pull the handle and see if the brake is releasing. If it is releasing then something in the recoil is defective. I hope this is of some help to you.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
Non-muzzleloader use
I never thought about it but I don't see why it would not work.The only issue would be recoil, and recoil is recoil.I am considering putting a scope on my Sharps replica and only wish it to look authentic.Good Luck
Nov 29, 2008 | Omega Nikon Muzzle Loader Rifle Scope...
Barska Optics Barska 10-40x50 Ir Swat Tactical Riflescope Ac10550 Logo
298 people viewed this question
Top Barska Optics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Barska Optics Optic Expert? Answer questions, earn points and help others
