Question about Celestron NexStar 11 GPS (660 x 279mm) Telescope
Celestron nexstar 8 i series alignment trouble
Last week I was finally able to get my GPS to align and locate objects off the menu.I set it up last night and was stunned to find that regardless of what alignment mode I selected ,it would begin to slew altitude non stop .I started it with barrel completely down in several directions.It would slew altide non stop bottoming out the barrel and still keep running! I tuned it off and regardless of what I did or alignment mode selected ,it would slew altitude non stop. I diosconnected my CN16 gps unit and it still would not cease slewing until I tuned it off.I have a computerized hand control # 93962 for my Nexstar 8i. Can you solve this problem?
Kind of late with my answer...BUT if you pop off your GPS unit and then just tilt it up and down CAN YOU HEAR a ball bearing moving inside...???
YOU SHOULD....that is how the GPS actually finds the level position of the OTA....sounds like it is stuck..OR even worst that you have a CN-16 unit that was designed for a GEM mount which is not designed at all for leveling the OTA...
Next thing.. exactly what version is your hand controller...version 2.3 ????
Bob G
Posted on Dec 30, 2008
    Problem Solver:
  • 5 Answers
Use the rewmote that came with the telescope and go into setup under telescope and push enter when it says calibrate motor
Posted on Nov 11, 2008
How do I allign it?
Use the finder scope to locate the object in question, then main scope will be aligned for magnified viewing.
May 08, 2016 | Celestron NexStar 130 SLT (306 x 130mm)...
Having trouble getting a Celestron Nexstar 114 to locate even guide stars? When I get an "alignment success" then pick an object,say m42 it takes off like it's looking for m42 but just keeps going and at...
Have you followed the instructions in the manual? The first thing to do is setup with the time, date and location, then select a 3 or 2 star alignment method to calibrate. Use ONLY the hand controller to move the scope to the stars.
May 30, 2010 | Meade Infinity 114EQ-DH Telescope
I have the Nexstar 8. It will not auto align or manual....
First do a RESET on the hand controller and make sure TIME, DATE, and SITE, are correct.
If this does not work then RE-load the firmware in the hand controller. If that fails contact Celestron customer service.
http://www.celestron.com/c3/page.php?PageID=37
May 15, 2010 | Celestron NexStar 102 SLT 102 mm (4.0)...
Celestron NexStar alignment problem
Several questions-
1. Are you SURE you are choosing the correct alignment star?
2. Are all the settings correct like-- Location, Time, Date, Daylight savings time.
Jun 18, 2009 | Celestron NexStar 102 SLT 102 mm (4.0)...
Set up
The finder scope may not be aligned properly with the mn telescope. In the daytime, try setting the main scope on a distant object such as a steeple or chimney in the distance then align the finder scope to point to the same object. Then at night, look at the some bright star or planet and fine-tune the finder scope's adjustment screws so the images are aligned between the two scopes.
Jan 24, 2009 | Celestron NexStar 8i (600 x 203mm)...
I recently bought the Celestrobn 6SE. I can opperate teh telescope itself..but have no idea what the software is about what on earth is a nextour software all about, I havent a clue..AND what is the...
I have also recently bought a Nexstar but mine is a 4SE. Im still pretty new at it myself but from what I understand, the Nexgps software is just the computer software to control the GPS unit from your PC - the same as the NexRemote software. If you dont have a GPS unit you have to purchase it as an extra so the software will only be useful if you have GPS.
The Nextour is just software that allows you to add objects you wish to see that the telescope will take you too in tour mode. Once you have it aligned of course.
I see this post was almost a year ago so you probably know all this by now.
Do you have any problems using the star align? Im really battling - gonna try 2 start align because it doesnt quite know where it is when I do the 3 star align.
Regards,
Bianca
Bianca.Haarhoff@za.syspro.com
Jul 20, 2008 | Celestron NexStar 4 SE Telescope
Telescope not self aligning by aligning to 3 objects
Please be absolutley sure that the mount is orthanogol (Level in all Directions ) to the plane of the instrument
Jul 13, 2008 | Celestron NexStar 80GT (189 x 80mm)...
Focusing Issue
The screws should be short enough not to stop the primary's travel, but pull them out and try it again. Good luck! George.
Jun 25, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
GPS not working
Nope! Sounds normal. The GPS is used as the surface point and time refrence, but it still needs the star fixes to orient the axis. 2 star alignment is generally for Alt-Az mounting, while you can use 1 star for rapid setup on a permanent equatorial mount.
Jun 12, 2008 | Celestron NexStar 11 Telescope
Celestron nexstar 11" gps scope
Be sure that the Azimuth Axis is Lock, you migth want to try and move the telescope in the Azimuth to make sure it is it is locked. Be carful not to force it. I have seen on some post where the locking part of the Azimuth somtimes breaks. and the Azimuth Axis will just spin freely Locked down or not.
May 19, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
Celestron NexStar 11 GPS (660 x 279mm) Telescope Logo
189 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
