Question about Kitchen Ranges
Could you please advised me how to take a bulb out of my Hoover oven and how to replace? Many thanks Jeanette Jollyjeanette@yahoo.co.uk
  • 1,031 Answers
Before doing any work on an electric range or oven, make sure it's unplugged, or turn off the power to the unit by removing one or more fuses or tripping one or more breakers at the main entrance panel or at a separate panel. If the range is fused at a separate panel, this panel may be located adjacent to the main panel or in a basement, crawl space, or other location. If there is a grounding wire to the range, disconnect it. Make sure the power to the unit is off.
you'll want to replace it using these simple instructions.
Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  1. Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  2. 3Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.4
  3. Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  4. Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back. 6
  5. Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb. In most microwaves you simply have to take the cover off by unscrewing holding screws. Replacing bulb is pretty straightforward, simply take out holding screws, disconnect leads, and remove bulb from place.
    To install new one,reverse steps.
    Usually it is really hard to find replacement parts. It is usually better if you take microwave name, model and serial number, and take info to a place that specializes in appliances
Tips & Warnings
  • Consider replacing the switch on the oven door if you replace the bulb and the light still does not work. Shut the door and open a few times or press the button manually to see if the light works randomly or not at all. hope this helps thanks and Godbless
Posted on Nov 06, 2008
Why cant I sign in to my e mail address pamster71@nokiamail.co.uk/
try without the slash at the end:
Nov 18, 2014 | Nokia C3 Cell Phone
Hi, The inner glass on the door of my Belling 295 SS built in single oven has completely shattered after just preheating it (quite hot although!). I bought it in 2007 so it would be out of warranty. Can...
Hi.
You should not need to replace the complete door, just the door glass.
If you have not already done so, then I would suggest you contact the maker direct, they should be able to help you.
Try the web site.
WWW.BELLING.CO.UK.
Jan 11, 2011 | Ovens
Need a manual for stoves 720 ef double oven
Supply an email address and I will register you on my BT Digital Vault where you can access and take a copy of the entire handbook
Dec 31, 2009 | Stoves 720EF Electric Double Oven
Lack of manual
You should have had the email from BT Digital Vault by now. Let me know if you have not.
Sep 16, 2009 | Stoves 720EF Electric Double Oven
I need a user manual for a Hoover washing machine model HNL6166
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=11
Just make sure you don't put a space between HNL and 6166. ie; HNL6166. The owners manual is there. Hope this helps.
Aug 30, 2009 | Washing Machines
Washing machine wont go into full spin
was advised could be bushes so replased them works a treat thanks
Feb 07, 2009 | Hoover Washing Machines
Dishwasher
Try here:
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=3
This is link for HD83M manual:
http://service.hoover.co.uk/manuals/pdfs/HD83.pdf
Hope this helps,
Tom
Aug 07, 2008 | Hoover 24 in. HD83M Free-standing...
HOOVER WASHING MACHINE
I have found a solution in a UK website. Machine fixed.
Jun 09, 2008 | Hoover Washing Machines
Manual for a Diplomat Select 620 single oven
Sent the manual to you Tuesday the 18th.
Mar 09, 2008 | Ovens
Kitchen Ranges Logo
262 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
