Question about Mitsubishi CS-35707 35" TV
TV lacks green, but has prominant red/pink 3
Here are some more pictures of the tube, crt board from the front and back. If you could explain my next step that would be excellent.
  • Kris Brand Oct 12, 2006
    inside of crt board
    back side
    Sergeant:
  • 337 Answers
Excellent pictures of the crt board I can actually see the transistor ans is mounted in a piece of metal with a screw holding it,is just to the right and he should be the only one of this kind in the board,this transistor is soldered in and it needs to be replaced with same,in its face it has some number ,the part can be ordered or cross to a replacement with those numbers.Make sure all the conections on the board are solid.Let us Know how it goes.
Posted on Oct 12, 2006
  • Omar Urrutia
    Omar Urrutia Oct 12, 2006
    The rating response is important to the person helping you.
After turning the tv on the colors are reddish and slow to conform to the normal color tones. i have a 36" toshiba flat screen tv
My first concern would be that, the picture tube is going bad. The problem you describe, tell me one of the color guns is shorting. In this case I would think the green gun is shorting. There are three color guns in the neck of the picture tube. They are red, green, and blue. Most of the time the green will short as it is powered heavily in most TVs. The next thing to check, is the small board connected to the picture tube. Look for any and all bad grounds on this CRT board. This is another big problem in all Tube type TVs. On this small board there will be three color output transistors, and resistors. These will many times run very hot and will create bad grounds over time. Check and resolder as necessary. If the CRT board does not fix your problem, replace the TV. Picture tubes are very expensive and will not be feasible for replacement. Search for a new TV. Thanks for asking and show all hands of support!
Jun 26, 2011 | Toshiba 36A43 36" TV
Television was alright when it was cut off. Next morning cut it on and the picture is all yellow and blue.
Tv is missing a color green,recheck ur tv Ant.hole coaxial cable input.Take the cable apart and reconnect to the Ant.hole again see if this help?Not make a fist with ur hand bang on the tv back cover frame see if the color green come back or flashes?Yes,than the tv CRT video board that is connected to the CRT- picture tube have cold soldering joints around it video board connections sockets,require resoldering the socket joints connections between the CRT video board and CRT tube connections socket.U have tools like a soldering iron,a roll of solders and can do basic soldering work?Yes,this problems just require resoldering that it.
Jun 10, 2011 | Sansui DTV3200 32" TV
Our orion t.v. started doing this this winter....it will all of a sudden lose the picture, the sound is still there but now picture. i can turn it off and a few minutes turn it back on and its there,. then...
Tv turn on,this happen.Make a fist bang on the tv frame,see if tv have a picture come back or have it flashes in and out?Yes,than tv is having cold soldering joints on the video board pins that connections to between video board and the CRT-(tv tube) those joints connections pins on the video board are to make the CRT-(tv tube) to have a picture.U have all the tools like a soldering iron,a roll of solder and also can u do basic soldering work?Yes,take the tv aparts.The video board,that the the board that connected to the CRT-(tv tube).Resodering all the soldering joints connections pins between CRT-(tv tube) and video board should solved this problems.Or tvs shops can do those resoldering for u,by telling them the problems.It should cost u like around $50.
Apr 10, 2011 | Orion Televison & Video
Picture went completely fuzzy. What could the problem be?
The tv CRT( picture tube) have a radiaton posion infected in ur tv picture tube.This is how u discharge the CRT(picture tube) get the posion out.Take the tv back cover off.Take video board that connected to the CRT(picture tube) out.Plug it in,so u have a live current to the CRT(picture tube).Find a wire like an AV cable,should be find.One side of the metal,grounded to the metal frame somewhere.Take a long needle plier grab the other side of the AV cable wire,not the metal,(Caution high voltage live current).Come very close to the open CRT(picture tube).U will have a live current arc,than u,will hear a big "POP".U,just discharge the CRT(picture tube).The tv now the CRT(picture tube),now it good,it clear of posion infected in ur tv picture tube.Now,unplug ur tv.Put ur tv,back together.Hook up ur tv signal cable and plug in ur tv,now ur tv picture,will be clear,completely.I do this many times to dicharge fuzzy CRT(picture tube).When i was a tv Tech.for the SONY TV Corporation.
Oct 12, 2010 | Sanyo HT32546 TV
The picture has lost focus and lost green
hard to say for sure, but the front opens up when you remove the bottom or edges. inside you need to inspect the CRT boards for any fluid leaks. there are focus adjustments on a black controller with 3 knobs on it. I would say take a look at the middle tube (green tube) if its dark and the circuit are dry. Try cleaning the CRT pins with the TV off, simply pull the cba/socket down and push it back up.
so lets see no green tube lite , cleaned pins no fluid, next tap it to see if it flashes bright, no OK now on the grn CRT circuit board slowly TV ON turn up the control you see and see if the green gets brighter. The CRTs are fluid filled and the fuild can get cloudy causing it to get dark and blury too. to check the fluid you would need to pull the screen off (a real pain)
these steps will help you isolate the isue and decide what to do next, hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 26, 2009 | Samsung HCN5527W 55" Rear Projection...
Poor pictre quality
This set has 3 CRT's (picture tubes)
Remove the back bottom cover
Clean the CRT's with windex and a soft cloth.
(Find the Screen/Focus block)----Remove front grill cover and panel which covers the Screen/focus block.
Cover 2 crt's and adjust the focus control for remaining crt---(using the convergence pattern in the menu for the set)
adjust for the best focus.
cover that crt and move on to the next crt using the same procedure.
After setting the focus on all 3 tube's you will have the best focus possible for this set. If picture is still bad, you have bad crt's and the set is junk.
Cost to replace the CRT's is enormous!
Craig
May 08, 2009 | Televison & Video
The picture on my Sony KP57WS500 is starting to fade to blue after being on a short period of time. ANY IDEAS?
Good Day;
A blue picture after it's been on for a bit is normally one of several things. The most common for your Sony is the CRT, tube, the second most common problem is the blue CRT 'IC'(chip). The IC is located is on the blue crt board.
The best way to determine this is to remove the speaker grill(on front of TV), then inner panel, the blue tube will be on your right hand side. Remove that little board at the end of the tube.THIS AFTER YOU HAVE UNPLUGGED THE POWER FROM THE WALL. Plug TV back in turn TV on. If TV comes on with picture and there is no blue in the picture, The tube is bad, if TV turns off it's the IC.
Good Luck, BI.
Jun 18, 2008 | Televison & Video
RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Dec 29, 2007 | RCA 27F634T TV
Sony big screen tv not playing picture after 5 minutes or so
You have a bad picture tube, or perhaps a picture tube drive problem.. To see what is bad, remove the front speaker grill under the screen in the front. Remove the screws that hold on the board that covers the front. Insidfe this set, WITH THE TV SET UNPLUGGED< Locate which one of the tubes is the blue one. Gently pull off the board from the end of the picture tube and swap it with the green tube right next to it. The green tube is always the middle tube. If the blue comes up again, then the blue tube is bad and you will most likely be better off to buy a new TV set. If the green comes up as the bright one, swap back the boards, call a tech and tell them there is a CRT driver board , or an RGB drive problem. This should not cost you an arm and a leg to get repaired. Good Luck, and let us know how you make out with the repair of this TV set.
Nov 11, 2007 | Sony KP-46WT500 46" Rear Projection...
Repair of my big sony screen tv
Televison & Video Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
