Have Bush CD/TAPE/RADIO. CD won't play but is spinning
    Sergeant:
    Champion:
  • 227 Answers
Try to clean the laser(pick up) i think that will do the job
good luck
caypianan@yahoo.com
Posted on Nov 06, 2008
I have an AKAI radio/cd/tape player combo. For about a year I had to toggle the switch around a few times just to get the radio to come on, now I cannot get any sound at all with the cd or radio
Akai used to produce quality gear. Today in common with lots of premium manufacturers the gear is less repairable and a whole lot more disposable. This is because it is less "engineered" and more designed for cost-effective assembly.
Mechanical switches and potentiometers for instance, add weight and expense to the manufacture and shipping and they wear out or get dirty and don't work - but they can be replaced or cleaned relatively easily. Soft touch controls and electronic switching is cheaper to produce and more pleasing to some buyers but when they go wrong cleaning rarely works and repairs are beyond the usual scope of the hi-fi enthusiast, meaning expensive repair-shop costs. It is worth attempting to clean the switches if there is access and you feel adventurous.
It sounds as though you have nothing to lose. There is a wide selection of switch and electrical cleaners available, some with an added lubricant for mechanical switchgear and potentiometers though for some things a cotton bud or a slip of paper dipped in methylated spirit works well.
Aug 10, 2016 | Audio Players & Recorders
Bose wave radio cd won't play cd's
If your CD is not scratched,the optical lens need replacement.
Apr 02, 2013 | Bose Awrc1g Wave Radio Cd Player Only -...
Boom box won't play CD
The Laser is more than likely the problem, but you can only replace with the whole assembly due to alignment issues, not cost effective.
Feb 21, 2012 | Audio Players & Recorders
Sharp CD-BA2100, when I turn it on it starts making a clicking sound and if set to tape one or tape two, it shows "error". When set to "cd" it comes up with error 0306 and the cd tray...
the rubber rope which conect the motor to a small gears to open the cd was cut due to long using ... this sound of clicking coz the small motor is running and its not attached to anything ... its a small rounded rubber rope ..the bad news is you have to break some plastic stuff to reach the motor in the repair depot they change the whole upper part so it costs alot ... but if you can reach it it will work perfect as its new.
Sep 08, 2011 | Sharp CD-BA200 CD Shelf System
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
I have memorex radio/cd/cassette player model MP3226. The PLAY button on the cassette tape does not stay in the down position when pressed when a tape is in the housing. If I remove the tape, and press...
I can imagine 2 cases for your problem:
Either there is a mechanical problem and something is not allowing the "play mechanism" to go all the way up to the clip position when the cassette is in the housing,
Or the tape isn't rolling up properly. Some of these deck's have some kind of protection and when the tape isn't rolling properly a system stops the play procedure. Check if both of the rollers for the tape are spinning around properly. In case of not spinning, run the cassette fast speed forward and backward in order to come to the proper state. Also check without any cassette is any roller spinning around or not?
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 15, 2011 | Memorex MP3126 Cassette/CD Boombox
The tape plays songs so fast sounds like donald duck. The speed the tape is feeding is to fast.
Hi, the casette deck has a mechanical system (servo-driver) most of the problems that happen when in your case, plays song so fast is that you look at the pinch roller. The pinch roller is a rubberized free spinning wheel typically used to press magnetic tape against a capstan shaft in order to create friction necessary to drive the tape along the magnetic heads with a normal tape speed if the pinch roller brakes, get lost from his place or got dirty then you get this fast sounds play, check the pinch roller if still good in his place or clean his rubber with alcohol, then the problem should be fixed.
Jan 29, 2011 | Sony CD Radio Cassette Boombox, CFD-E90...
I have inherited a Sanyo 3-disc CD changer system with radio and tape-to-tape deck. When I tried to put a CD (a copy made on my computer) into the system it would not play, so thinking it wanted a...
i have the same problem and when I opened it I noticed that it wasn't spinning the disc fast enough, if anyone knows how to fix this or if we can just swap the motor please help!!
Sep 17, 2010 | Audio Players & Recorders
Radio 80c7e80b will not play, only get static on AM/FM CD Works
your radio is shot, and the cd and tape player still works. You have to buy a new radio if you want to listen to a radio.
tepfy
Jun 10, 2009 | 2002 Chrysler Town & Country
Cd player cant read disc
Check that the disk is still spinning. If not then suspect the spindle motor
Mar 23, 2007 | Sony CFD-S350 Radio/Cassette/CD Boombox
 Grubhead
Grubhead
