Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
Cant get oven to work
Maytag stove mgr4452bdw
  • ponc Dec 02, 2008
    pushed for cleaning know f3 has taken over the controle panel with every thing i try no oven use
  • Anonymous Jan 18, 2009
    Nothing happens when we turn the oven on--there is a glow from beneath, that is all. No flame.
    Genius:
  • 1,239 Answers
Hi Step 1: Take out the screws that hold the panels, and pull off the control knobs. On the control panel the knobs are friction-fit; pull them straight off. Some knobs may have setscrews in the base of the knobs; back out these screws using a screwdriver or Allen wrench and pull off the knobs.
Step 2: Remove the back service panel on the control panel by backing out a series of screws around the edge of the panel. To remove the front panel, take off the control knobs and remove a series of mounting screws that hold the decorative panel to the frame. These screws may be hidden by molding or trim; pry off the molding or trim with a screwdriver, or take out several screws.
Step 3: To gain access to the burner assemblies, remove the burner grates and then the top of the range. The entire range top should either lift up and off the range or open up and back on hinges. The oven door can usually be removed by pulling it straight up off the hinges on both sides of the door. Some hinges have a latch that must be unlocked before the door can be removed.
Step 4: If the surface light of the range burns out, remove retaining screws and panels as necessary to gain access to the bulb. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the old bulb for this information. Then replace any retaining panels.
Step 5: If the oven light burns out, unscrew it and remove it from the oven. Replace the burned-out bulb with a new one of the same wattage, made for oven use.
Posted on Nov 06, 2008
Stove top works , oven does not
If the ignitor is not glowing to lite the oven then it needs to be replaced. Here is that part to order.
Whirlpool 74007498 Oven Ignitor AppliancePartsPros com
Mar 20, 2014 | Maytag MGR4452BDW / MGR4452BDQ /...
I have a black Maytag Gas Range stove the oven wont heat up. The ignition what i think it is, is glowing but when I tap the bottom of the stove it will light. What part do I need and where can I get it....
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
The oven won't heat up anymore. It was fine and now doesnt work. The broiler works fine and stove top is fine.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 29, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
I have a maytag mgr4452bdw gas stove.The top burners work fine but the oven itself will not ingnit.What could the problem be?
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Jan 27, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
The Maytag gas oven Model: MGR4452BDW and Serial:
Are you sure it's clean/ Does the smoke smell like wire burning or plastic? Is there a chance that there is some left over spill just burning off?
Jul 22, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Stove wont light but no gas smell
sounds like a weak ignitor they look like they're working but not getting enough current to open the saftey valve
Jun 30, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Electriic oven control broken
maytag #mgr4452bdw the clock will not set the face reads 5-A-6 and the oven will not come on
Aug 27, 2008 | Maytag MGR4452BDW / MGR4452BDQ /...
Free owners manual
hi there,
go to www.whirlpool.com
then scroll down to the bottom right and you'll see customer support and then manuals & literature.
click on that and then type in your model #.
all the manuals are in .pdf, so make sure that you have Acrobat Reader.
May 20, 2008 | Maytag CWG3100A Gas Single Oven
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
272 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
