Question about Sony Cyber-shot DSC-T10 Digital Camera
Blurring on one side - Viewing and photo
All my pictures are coming out blurred on the left hand side. This seems to be a problem with the camera, as when I look through the viewer before taking a photo, the viewing image is blurred on that side too.
This problem seems to have just occurred, as when I last used the camera only a couple of weeks ago the pictures and viewer image was fine.
A friend managed to find a very easy solution to this problem...the lens was dirty due to a 6 year olds sticky fingers...so I just needed to clean it.
Posted on Nov 07, 2008
Blurred edges
blurring occurs not depending on ISO, i think the lens is the problem. try to clean the lens glass carefully, is there some grease stick on the lens? if not it might be dislocated one of the lens structure.
have you try another lens?
Jul 26, 2013 | Canon EOS 400D / Rebel XTi Digital Camera
I have a nikon 55-200mm lens for the D40X digital camera. The pictures I take are blurred. I use the auto settings. the 18-55mm lens works fine and there are no problems with the picture clarity. Is the...
One of a few things might be happening
1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself.
2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light.
3. The camera may be focusing on something other than what you intended.
3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario.
If the lens is "hunting" for focus, that could be a sign that something is amiss.
A local camera shop can verify the accuracy of focus for your lens.
Mar 04, 2011 | Nikon D40x Digital Camera
I use 50mm Nikkor with D300s. If I try to increase the aperture by 22 to get better depth of field it comes blur. why is that? Do i need to change the camera settings?
When you set the aperture to 22, you decrease the amount of light coming through to the sensor. Hence, you camera compensates by increasing the shutter time. With the decrease in shutter speed, you have a higher can of blurring the picture if you're holding the camera by hand. Try mounting on a tripod to keep the camera still. See if that helps.
Oct 26, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
When taking night sport shots I don't think I have the right settings for clear photos they are coming out tooo blurry. Help!!! the photos are grainy also and dark. Could you send me the correct setting...
More likely you don't have enough light for clear photos. There's not too much you can do about this, since you probably can't add more light to the stadium or arena and the action is too far away for your flash.
Since the low light is going to force a rather slow shutter speed on you, you need to stabilize the camera. Use a tripod or monopod. That won't stop the athletes from blurring, but at least the setting will be sharper. Alternatively you can try panning with the motion, freezing the athlete and blurring the background.
A faster lens will get you a couple of additional stops, but as such lenses can cost $2000 and more, unless you're taking pictures for Sports Illustrated...
Sep 11, 2010 | Nikon D70s Digital Camera
Blurring pictures
I had the same problem. Somehow my flash was set on "SL - Keep subjects and distant backgrounds bright." When I changed the flash to "Auto", it seemed to get rid of the blurry pictures.
Dec 08, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
L11 Blurring
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Jul 15, 2008 | Nikon Coolpix L11 Digital Camera
Olympus u 700
In on postion in camera mode,the lens seems to move in and out,blurring the image and then stops with this message on screen. D: 5f O8 5eO2
Jun 26, 2008 | Olympus Stylus 710 Digital Camera
Blurring of close subjects and items.
Have you tried putting it into macro mode? (look for buttons or menu options with a picture of a flower). A.
Mar 11, 2007 | Canon PowerShot S2 IS Digital Camera
Major blurring/sharpness problem with Pentax Optio 50; help!
Thanks for posting the photos.....they tell a lot. You need to return that camera and get a refund. The camera is defective. The first two photos were taken under good lighting conditions and you should have gotten good shots. The last two were taken at low light and the camera was using 1/30th of a second shutter speeds which could account for some blurring due to camera movement. The last one appeared to be a flash shot and it selected 1/30th second. Not a good thing for the camera to do. But all photos have the appearance that you are shooting through a fog. And all photos were shot with an ISO setting of 200. There is something wrong with this camera for that to happen on the first two shots. I checked the EXIF data that is embedded in the photos. That gives you the shutter speed, aperture setting and focal length, ISO settings, and other information. I have not seen a review of the Pentax Optio 50. But the older S50 did not get good reviews. If I were you, I would look for a different brand of camera. For a few dollars more you can get a Nikon 5600.
Aug 30, 2005 | Pentax Optio 50 Digital Camera
Sony Cyber-shot  DSC-T10 Digital Camera Logo
104 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
