Question about Samsung RS2630WW Side by Side Refrigerator
Control panel erase from the windows
My control panel is not working. Everytime I click the task for the control panel , an error is always alerting to my desktop stating to consult administrator and need technical support.. Could you please help me activate the control panel in my computer. Thaks a lot.
    Genius:
  • 1,239 Answers
Hi The thermostat control is usually mounted inside the refrigerator. Its visible control knob is turned to regulate the refrigerator/freezer temperature. The workability of this control can be tested in various ways, depending on the problem. To test the thermostat control:
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Posted on Nov 06, 2008
I have lost ALL of my taskbars!! How do I get them back?
A program called explorer.exe controls the display of your taskbar and desktop icons. If for some reason it goes missing (you may have killed it using Task Manager, for example, or something more sinister like a virus has deleted it from your processes), then try this first:
  1. Open Task Manager (press Ctrl+Alt+Del, then click Task Manager).
  2. On the Applications tab, click New Task at the bottom right of the window.
  3. Type explorer.exe, then click OK.
If nothing sinister caused it to disappear, it should all come back as it was and you can stop panicking, breathe a sigh of relief, and continue working.
If that doesn't work, then try this:
  2. Go to the Processes tab.
  3. Click on the Image Name column header to sort the list alphabetically.
  4. Find all explorer.exe processes - select each, then click End Process for each one.
  5. On the Applications tab, click New Task at the bottom right of the window.
  6. Type explorer.exe, then click OK.
Are you using snagit, try to uninstall it and then check if you still get the errors. If you donot use snagit then there would be another error.
If you cant access control panel use the "Windows Key+R" on the keyboard which opens the run dialog and type in 'sysdm.cpl' which opens the control panel.
You could also try to restore you windows using System Restore and select a date of the backup when the computer was working well.
Make sure you do a complete virus scan with a good antivirus with updated virus definitions as it could be a virus too.
Jan 21, 2011 | Computers & Internet
Tip
Windows XP Tweaks
Services to turn off:
Alerter
Application Management
Automatic Updates
ClipBook
Distributed Link Tracking Client
Error Reporting Service
Fast User Switching Compatibility
Messenger
Portable Media Serial Number Service
Remote Registry
Routing and Remote Access
Task Scheduler
Telnet
TPC/IP NetBIOS Helper
Uninterruptible Power Supply
Change "Recycle Bin" size to 1%
Registry Hacks:
Auto Sort Start Menu
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MenuOrder
Go to Edit/Permissions, click Advanced, clear the "Inherit From Parent" check box, click Copy from the dialog box, click OK and then clear the "Full Control" for your account and now Windows will autp sort the start menu, but you can still do it too
Disable User Tracking
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
Add or Edit DWORD = NoInstrumentation, Value = 1
Disables Windows user tracking; better performance, much better privacy
Cache Thumbnails
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
Add or Edit DWORD = DisableThumbnailCache, Value = 1
Disables thumbnails in Windows, saving hard drive space
Kill Chrashed Apps Quicker
HKEY_CURRENT_USER\Control Panel\Desktop
Add or Edit Sring = HungAppTimeout, Value = 1000-5000
Cuts time for Windows to recongize a crashed application and allow you to kill it; default is 5000(for 5 seconds)
Faster Start Menu
Add or Edit Sring = MenuShowDelay, Value = 0 - 400
Changes the delay that for Windows to show a menu in the start menu; value is in ms
Network Intelligently
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters
Add or Edit String = DisableTaskOffload, Value = 1
Frees processor from doing network-card work
Browse the Network Faster
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\RemoteComputer\NameSpace
Delete subkeys {2227A280-3AEA-1069-A2DE-08002B30309D} and {D6277990-4C6A-11CF-8D87-00AA0060F5BF}
Speeds up network browsing of old Windows machines on the LAN by ignoring their scheduled tasks and printers
Remove Compression Option In Disk Cleanup
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\VolumeCaches\Compress old files
Delete the Default Value Key and the next time you start Disk Cleanup, it will skip the compression analyisis
on Dec 19, 2009 | Computers & Internet
Iwasprinting a task then I decided to delete the task. The printer is no longer working. Uninstalled the program and then re installed with CD. a box indicating a fatal error comes up. I cannot use my...
Hi Mprasad90,
It is always recommended to complete the task when the command is working, Fiddling while printer is working may leave the printer in no where stage.
I think your printer needs a L1 uninstallation which will remove all the Vid & Pid entries from the system registry.
Also the spooler service in system might stopped it needs to be restart. please consult the vender if the printer is in warranty!!
Oct 15, 2010 | HP Deskjet 2460 InkJet Printer
Missing battery indicator in the task bar
No this is more typical with Windows Vista users as updates can disable the icons from the notification bar.
Chose 'taskbar' tab, then click 'customize' and chose the option for the battery icon and change to 'show' .
If you need anymore help please post back.
Regards.
Nov 26, 2009 | Microsoft Windows XP Home Edition
Bounceback error 0003
This error is due to the settings in your firewall . Please check the windows firewall settings as mentioned bellow:
. Click Start and then click Control Panel.
2. Double-click Security Center. (You can also access the Security Center by clicking on an alert sent by the Security Center. For example, if you receive an alert telling you that your antivirus software is out of date, when you click that alert, the Security Center will open.)
3. In the Security Center, under Firewall, click Recommendations. (The Recommendations button is not available when your Firewall setting is marked ON.)
4. In the Recommendations dialog box, select the I have a firewall solution that I'll monitor myself check box, and then click OK.
Let us know if your have any doubts.
Thanks
Nov 20, 2009 | Computers & Internet
Task bar is grey upon start up
^Try going do the display properties again but this time on the Appearance tab.
You will have a dropdown box and select windows xp default.
let me know if it helps
Jun 20, 2009 | Microsoft Windows XP Home Edition
Keep receiving restriction error
it sounds like your not loged in with administaters
good luck
Mar 18, 2009 | Dell Dimension 2400 PC Desktop
Windows explorer stops working and restarts when i try to access my control panel from the start menu
try this go to c:\ right click to properties on drop down menu.
tools on the popup fix error tick box click check now reboot computer on startup computer should scan disk for and fix any errors. this method has worked on a few computers but does not work everytime as something else is basically wrong
Jul 16, 2008 | Computers & Internet
Alert on low storage space
go to settings and click clear storage and it will reinstall everything
Dec 23, 2007 | T-Mobile Dash Smartphone
Want to know applications of DMA in real time
Good Morning
IT it a little "brige" to some sound aplications or routing signal to Printers or Sound Cards, but not for Network. Not good sometimes for Sound Cards, but you can play sometimes with settings and see what happend, you always can go back the DMA at previuos state, or simple, disable.
Carl
Nov 17, 2007 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Samsung RS2630WW Side by Side Refrigerator Logo
114 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
