Back to:
Tags:
Magic Chef CYE4000AWW Electric Dryer
Dryer stopped working (by 2 users)
posted by plumber on Oct 12, 2006
magic chef dryer (electric) stopped working,door light doesn't work. panel lights up. At last use dryer was on for 10 min, clothes came out exceptionally hot.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by moidyboys, posted on Mar 15, 2008
whirlpool dryer stopped working after finished drying one load, nothing seemed out of the ordinary, just didn't come on after the one load was done???? model #LEQ903PQO, did clean out the lint and everything else, I did check the light bulb on inside and was burnt out, haven't changed that yet, don't know what else to do???? please help!
Best Solution
posted on Oct 12, 2006
FixYa! (100)
catriver
Rank:Guru Guru
Rating: 94%, 2640 votes
plumber, pop the top on the dryer by pushing on the two clips just under the top on each side. In the back you will see the heater. You want to check the high limit thermostat (this one sits on the top side of the heater) and the thermal fuse (sits on the side about 4 inches down. Unplug the dryer and check them with a meter. If either shows open (no continuity) replace them. Make sure your venting is not clogged up and the heater is not grounded or fractured. Part number for the high limit is 53-0771 and for the thermal fuse is LA-1053. Check these first...Catriver...post back.
Unable to find your exact model, but I do have cye4000ayw. parts should be the same.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on dryer stopped working:
I don't want to Accept this solution
Can you Help with these Dryers problems?
Dryers
Just changed rollers and belt. Went ok...until it ran...
Dryers
The on off button wont stay on. Can I repair it ?
Dryers
drum support wheel needs replacing
Dryers
I have a ctd00p dryer and cannot get the worktop off to...
Dryers
What is the alarm code E01? What does it mean?
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
