Question about Toshiba 160GB EXT-USB 2.0 PRTBL SHOCK MOUNT 160 GB Hard Drive
Toshiba hddr160eo3x Hi I have a toshiba usb drive 160gb and it is ticking and not starting up..... Any suggestions?
  • eighty7_eigh Mar 22, 2009
    i have same problem my HDDR 160GB can not work how can repair????????????
  • 95 Answers
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Posted on Nov 30, 2008
    Genius:
  • Toshiba Master
  • 1,250 Answers
Check it on some different usb port or in different system, if its not detecting there also, then take out the drive from the casing , put in a new casing then check
Posted on Nov 06, 2008
I have Memorex Ultra Traveldrive - 160GB USB Hard Drive. I dropped it by accident and now I can't get information stored in it. Please help!!
1 what happens when you plug it in ?
2 can you see it in disk management ?
3 does it make any noises when plugged in ?
Gently tap the hard drive with an opened hand and see if you can get it to spin up one last time.
click start control panel administrative tools computer management disk management if you can see your drive right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Some addition links found on Google
http://www.datarecoveryreview.net/
Of course it can be sent to a data recovey company if you really have to get the data off.
hope this helps
Oct 12, 2012 | Memorex Ultra Traveldrive - 160GB USB Hard...
hope this helps
My drive fall form table i was tryed it is not working and not able to read my data that drive needle getting tick tick sound coming what can do?
The continuous "tick tick" normally means low power on the device.
Means: Case board broken or hdd logic board fault.
Possible solutions:
- Try to change usb port and usb cable.
- If you have an usb power adapter try to connect it JUST for some seconds to see if the disk spins.
Warning: you can burn your disk because the classic usb omputer port use a 500mA max power while an USB A/C normally can offer up to 2000mA.
- Buy a cheap 2.5" hdd case and put on it your 160gb hdd because the board of the Apollo could be broken. In this case check before buying if you need a SATA or a PATA interface.
If nothing changes, sorry, your hdd is probably dead.
Sep 13, 2012 | Imation Apollo Portable - Hard drive - 160...
Toshiba jump drive usb 16 gb problem
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
if still no joy
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps
Jun 06, 2012 | Toshiba Computers & Internet
Hey.. I have a toshiba 160GB portable hard drive and its got very important data for my work.. a while back it used to just stop working when i view some old files and then all of a sudden it just...
give the hard drive a firm tap on side it sounds like a dirty hard drive the clicking sound is the reader arm scating across the platters once you get access to your hard drive then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive
good luck with this
Sep 03, 2010 | Toshiba 160GB EXT-USB 2.0 PRTBL SHOCK...
WD Mybook External Hard Drive
Sounds like it's gone bad. I recommend these guys, if it's recoverable at all. I used them on my last job and they came through with all the data: http://www.gillware.com/
Feb 18, 2010 | Seagate 160GB 3.5" External USB Drive 160...
160gb usb 2.0 portable hard drive that is froz
Try plugging it into a different USB port may not be enough power from that port
Dec 06, 2009 | Iomega Computers & Internet
What to do with a portable toshiba hard drive that clicks
A hard drive that is making clicking noises is faulty.
Replace the hard drive in the portable Toshiba case.
Oct 09, 2009 | Toshiba 160GB USB 2.0 Portable External...
Toshiba 160GB EXT-USB 2.0 PRTBL SHOCK MOUNT 160 GB Hard Drive Logo
548 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
