Question about Olympus IS-3 DLX 35mm SLR Camera
Camera will not turn on
The camera let me take the pictures for couple post then it's turn of, and I replace with new batteries but the camera still not turn on. Need help, thanks in advance.
  • Anonymous Feb 23, 2009
    Took 5 pics then the camera acted like the batteries were low only they were new and verified to be charged.
Put in new/better batteries...rc
Posted on Jun 04, 2009
Canon PowerShot A480 won't take photo. Pressing on button camera on then pressing silver button to take photo when pressed down screen turns black no picture taken. Batteries new. This is the story; camera...
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
Jun 20, 2010 | Canon Powershot A480 - Silver Digital...
Camera works for a very while, but quickly senses low battery and shuts down. Won't work more than a couple of pictures with 2300mAh rechargeables, maybe 10 pictures with alkaline. Seems oversensitive to...
Something, it sounds like, is draining the batteries. Rechargeables are a lower voltage, and don't last as long as alkalines, but the alkalines should give you at least a couple hundred pics (depending on how much the flash and zoom is used, camera turning on and off, etc.). A camera tech might know the likely cause, but get an estimate before getting it repaired. The cost of service is often more than the replacement cost of a new camera, as they are getting cheaper by the day, almost! Good luck, sorry I can't help any more than that.
Mar 17, 2010 | Olympus SP-320 Digital Camera
Won't take pictures
I would suggest the first thing do is to replace the batteries with new ones. It sounds as though the batteries are low (perhaps they won't charge fully anymore) and that is why your camera is switching off.
It is always worth trying the simple things first :)
If this doesn't work and your camera still won't switch on please post back.
Nov 09, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Powers on, lens extends, 3 beeps, lens closes, camera turns off
Try doing a couple of things.
1) remove and digital media cards.
2) turn the camera on and delete any pictures that may be stored in the camera memory (not on a removeable card)
3) remove the batteries for 60 seconds
4) replace the batteries without the media card and lay the camera on a flat surface with the lens pointing up (5) The lens should retract.
6) Turn off the camera
7) replace the media card and turn on.
I think the camera was getting hung up on the pictures stored in the camera's memory.
Aug 17, 2009 | Cameras
Kodak Z740 digital camera
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 08, 2008 | Kodak EasyShare Z740 Digital Camera
Turns Off
Hey MaryKing,
I would first try taking out the batteries and waiting a couple of minutes and reinserting them, and if this doesn't work I would try a new set of batteries (battery manufacturers' sometimes do make faulty products). The next thing you could try is cleaning the battery contacts with a soft dry clean clothe. If you can access your set up menu there is a reset option that resets the camera to the manufactures default settings. If none of these options work I would have it looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 29, 2008 | Kodak EasyShare Z1275 Digital Camera
Short or No Battery Life
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.
Hope its helpful to you
Oct 09, 2007 | Canon PowerShot S1 IS Digital Camera
Camera won't stay on / powered!
I have the same problem with my camera and the following activities solved it. Remove batteries and clean contacts of battery's host (include cover). Check as well that contacts are not bended and didn't lost their springiness. Good luck!
Aug 08, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Nikon coolpix2100 not turning on
what does the manual say about the Green LED? Take a look through this list http://www.fixya.com/support/p438-nikon_coolpix_2100_digital_camera/solutions
May 20, 2007 | Nikon Coolpix 2100 Digital Camera
Olympus IS-3 DLX 35mm SLR Camera Logo
159 people viewed this question
Top Olympus Photography Experts
David Payne
David Payne
Ron Mccartney
Tom Chichester
Are you an Olympus Photography Expert? Answer questions, earn points and help others
