Question about Compaq Presario Notebook
Driver probs i installed xp on my compaq presario v3000 series, serial gn367pa#acj,and i need the audio driver and graphic driver?couldn?t find any?so could anyone help me out here??any download links??
  • kadaj Nov 06, 2008
    actually its a v3424tu model..ive tried those drivers but didnt work..
  • shekhar01bgp Dec 02, 2008
    i have problem with NIC Of Marvell Yukon Of Compaq Presiro V3000 Notbook.
    My OS is RedHat LINUX.
    Novelist:
  • 171 Answers
Here's a link where you can download the drivers for your presario v3000 laptop.
Compaq Presario V3000 CTO
Posted on Nov 06, 2008
Are 2002 Aztec computers compatible
I am assuming you are discussing the 2002 Pontiac Aztec, the early crossover with the rather distinctive look. I would assume that since they were made by the same manufacturer and they used the same parts that their computers should be compatible. I can't say so for certain as you haven't provided much information, but, unless one of the Aztec owner swapped out the original computer and replaced it with an updated device, the computers should be compatible.
If you are thinking of trying to swap computer chips, I would advise you to wait and let a professional do it at an independent shop. The reason I suggest this is simple, unless you know how to access the computer chip correctly, you risk accidentally ruining it. If you handle the replacement chip incorrectly it is entirely possible that for a stray static charge to ruin the chip by blowing out a trace. Also, if you damaged the socket from which the original chip was removed then it is possible that you will not be able to reinsert the new device without bending any leads on the bottom. If the leads are damaged, then the new computer won't work.
Even if the new computer chip and the original chip were already installed in installable cases (the way most desktop computer chips are installed), it is possible that when you removed the computer, you might have damaged the receiving socket which means that when you go to insert the new computer carrier it won't work correctly because a few or many of the pins on the bottom of the board won't sit correctly.
Jan 03, 2015 | Computers & Internet
9.9 merc outboard serial # 114058 what year is it ?
The best I can tell the year would be 1986.
Is the Serial number A114058?
Jul 03, 2014 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
Speakers don t work
try checking windows control panal too see if you have drivers installed. if o.k. try sound icon to see if you have ticked mute box. here's the one that got me,the dvd playing program had the mute box ticked. re-launch dvd played/media played and un-tick. good luck
Nov 10, 2013 | Computers & Internet
How to record from sound card on Lenovo T430
If you can play a MP3 music file already, why would you want to record it?
If you want to convert the MP3 file to a WAV file all you need to is use a conversion program.
Click on this link for instruction on converting music files to mp3 or WAV file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Apr 03, 2013 | Lenovo Computers & Internet
Need driver for wm382200bg
You should be able to find the driver you need here. http://www.softwarepatch32.net/flwm382200bg.htm
Feb 05, 2012 | Computers & Internet
How do I start bluetooth on the qosmio g25-av13?
Try the ff:
1. Are you also using a wireless internet? If you are and you cannot also connect on wireless, make sure that the wireless is enabled on your laptop. On the left side of the laptop there is a on/off switch push the switch to on. (beside the usb port).
2. if it is already on, make sure that the bluetooth is enabled also, you can check it on control panel, system, hardware, device manager, bluetooth, right click on bluetooth driver, if you see enable bluetooth click on it, if you see"disable bluetooth" that means it is already enabled.
3. If the above is already configured, lastly, look for the bluetooth icon (bluetooth manager) on the lower part of the screen on the taskbar/tray if you see the bluetooth icon, right-click on it then click "Enable Bluetooth Radio". Now, if there is no bluetooth icon on the tray at the lower right of the screen, go to Start, Toshiba, Bluetooth, Bluetooth Settings, inside the Bluetooth SEttings, click on Bluetooth, Options, CLick on Enable Bluetooth Power, also, inside the Tray Icon (still inside Bluetooth Settings) select an icon so you can always see the status of your bluetooth on the Tray and you don;t need to do and check everything everytime you cannot connect via Bluetooth.
Hope this helps.
Tricia
Aug 19, 2008 | Toshiba Qosmio G25-AV513 Notebook
Compaq Presario Notebook Logo
304 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
