Question about Beko 24 in. D3421F Free-standing Dishwasher
Dishwasher Fails to drain and cuts out via float switch?
Hello, My dishwasher runs part of its program and cuts out due to water level rising and cutting out mid program due to float switch. When i take the rotary knob past program 4 to bottom dead centre and hold the start switch in to drain it drains sucessfully but it takes about 10 attempts to drin the dishwasher fully. Any ideas on how i fix this problem?
Regards
Gary
  • Gary 'Pug' Pugh
    Gary 'Pug' Pugh Nov 06, 2008
    I think the float switch is working. The dishwasher is cutting out mid cycle because of water level in the dishwasher. I have the Beko DWD 4310 S. It was purchased from currys i think. I didnt see an option for my specific type of dishwasher. I imagine it is different to the one i put it under in this forum. Anyway, the water isnt draining from the system and it is being cut off by the float switch. I can manually drain it but it takes several attempts to drain it with the pump. I dont know why if i can drain it manually it doesnt do it during the wash cycle?
    Genius:
  • 1,239 Answers
Hi Dishwashers are usually protected from overfilling by a float switch. This switch is located in the bottom of the unit. Here's how to check and replace it:
Step 1: Open the door and remove the bottom dish rack. Check to see if the float valve is stuck. If it is, clean away food debris around the float. With a screwdriver handle, lightly tap the top of the float to free it.
Step 2: If tapping doesn't work, remove the lower access panel and locate the bottom portion of the float and float switch. Test the float switch with a VOM set to the RX1 scale. Unscrew one electrical lead wire to the switch terminal, and clip one probe of the VOM to each terminal. If the meter reads zero, the switch is not faulty. The trouble is probably in the timer. If the meter reads higher than zero, the switch is faulty.
Step 3: Replace the switch with a new one made to fit the dishwasher. The switch is held to a mounting bracket with screws; remove the screws to get the old switch out.
Step 4: Connect the new switch the same way the old one was connected.
Posted on Nov 06, 2008
I just bought a dishwasher SE34E200SK. The washing program always gets stuck in program 3 and it cant move further unless one has to turn it manually. Also it doesnot empty out the waste water after...
Hello
Most faults can be referred to the fact that the Anti Flood Overflow device has activated.
Modern day dishwashers like those manufactured that have a built in safety feature protecting the dishwasher against flooding. The technical term is 'Anti Flood Device'.
In the base of the dishwasher in the plinth there is a float switch. This is your 'Anti Flood Device'. In the event of your dishwasher over filling, the plinth fills with water, the float rises and actuates the switch.
Firstly, it will send a signal to the programmer device to notify there is a fault and output a message in the form of a code to some sort of display.
Secondly, the pressure switch acts as the water level indicator for the sump of the dishwasher so when the water level rises the pressure switch will activate the drain pump.
So before you consider throwing good money at new dishwasher, try doing a bit of fault finding your self and you might save yourself a ton of money.
Sep 10, 2011 | Dishwashers
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
My dishwasher draining but does not take water in
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back if you need more information.
Daniel
Jun 07, 2011 | Danby DDW1805W Designer Series...
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
My dishwasher does not fill with water
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Feb 21, 2011 | Bosch SHU5315UC Dishwasher
Power goes to dishwasher, buttons lite up, does not run and no water starts.
Hi
Daniel
Feb 10, 2011 | Whirlpool Dishwashers
Dishwasher runs but gets no water...
Hi
Daniel
Jan 31, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
The washer is not getting any water. It is running dry.
Hi
Daniel
Oct 25, 2010 | Kenmore Dishwashers
Dishwasher will not fill with water
Hi
Daniel
Oct 07, 2010 | Bosch Dishwashers
Will not fill and will not run even when filled by hand.Is it the circuit board?All fuses and switches are good.
Hi
When the Dishwasher is not filling in, you’ll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don’t get any value on the multimeter hen you'll need to replace the water inlet valve assembly.
Daniel
Aug 26, 2010 | Hobart Dishwashers
Beko 24 in. D3421F Free-standing Dishwasher Logo
1,048 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
