Question about Denon DN-600F CD Player
How do I replace a damaged power supply transformer on a DN-600F ?
Hello, I plugged my 120VAC made-for-USA Denon DN-600F CD player into a 220VAC power outlet, and the CD player won't work now. I looked inside to see if there was a fuse I could replace...but there was no fuse; so it must be that the high voltage damaged the power supply transformer inside. I would like to try to replace the transformer myself...either by getting it rewound, or by finding another transformer with similar specifications. Could anyone help me, and tell me what the specifications to that transformer are ? There's nothing much written on the transformer or the circuit board that I can understand......it just says .66 on the transformer, and maybe another number with no indication to what the number describes. I would be grateful for any advice - anything I need to know to undertake this repair. Thank you.
    Problem Solver:
  • 11 Answers
Hello there. i'll suggest you one quick solution but it maybe dangerous!(Do it the greek way :P) try to remove the transformer from the machine. Take one Ohm meter and measure the resistance of the 120 vac coil. IF THERE IS NOT ANY (i mean that the ohm meter shows nothing diferent than not using it) get a paper blade and start removing the paper cover that it has rounded from the place where the 120 vac wires goes. you will see there that there is a mini thermal fuse.short circuit the thermal fuse and try to measure again the resistance of the 120 vac coil. if you see something between 40 and 80 ohms you are ok. Now that you haven't got any thermal fuse on your transformer just increase your security putting on a 300 mA fuse at the 120vac coil. I have done it with many hard to find transformers and it worked for me.Just be sure that when you plug it on, you will not touch it because i don't know if you are gonna do it right.ok? (say ok!) That was the second solution to your problem. The first and the safest is to go to your local dealer and order a new transformer.
Posted on Aug 10, 2007
We just got a Wansa TV but it has a 220V plug. Will tv convert itself to 120 if we use a regular power plug
If there is no indication in the user manual or any spec listing it may not. Most of the time the power supplies used are for the full range of voltages available. It will not damage it to try. Get a power adapter instead of chopping the wire and putting on a new plug. If this does not work, buy a step up transformer 120VAC to 220VAC. Make sure the transformer is rated to at least 30% or greater for the wattage specs. If not the transformer can run too hot.
Apr 02, 2017 | Televison & Video
The platter for the denon 3700 keeps stoping
http://usa.denon.com/us/support/pages/Service-Network.aspx . Since it's a direct drive platter the motor or control circuits are giving you a fit. Check out the URL above for all the information you never wanted to know.
Jul 16, 2014 | Denon Dn-s3700 Dns3700 Dns S 3700 Cd...
My computer wont start up. The power supply light flashes green when plugged in then red. But still nothing , can someone please help?
Try a Power Supply Unit (PSU) Reset: Unplug the electrical cable from the wall and the PSU (Back of Computer)
Move the red voltage selector to the opposite position it is in and then slide it back. If you live in the USA 120Vac to 220Vac back to 120Vac
After you have done this you can plug the power cable back into the PSU. Connect the power cable to the wall power. If the PSU is still serviceable it will no longer be blinking.
2c170cb8-7c41-4ef0-8a3f-ff232e57320e.jpg fd10abb2-6218-42f0-8857-b761fffbcecd.jpg
Jul 08, 2013 | HP Compaq Business d530 PC Desktop
Replacing laser assembly/mechanism on Denon DN-C635 CD player.
Don't usually have to do any alignment when replacing the pickup.
Mar 13, 2013 | Denon DN-C635 CD Player
Denon 600df
Check with Hi Fi Engine, owner-manuals.com and then stereomanuals.com to see if the manual is there. Then deal with the problem. Some units are old enough to not be compatible with CD-R. It will say in the manual.
Jan 24, 2013 | Audio Players & Recorders
I have bought an ONKYO HTS-6300 from the USA (120V) and tried using it in India (220V) using a step down voltage converter. The receiver shows the red light but unit does not get on. It keeps on making a...
Hello
You have to use a step down transformer with this set and not a converter. The AC household voltage in Inda is 220VAC. Your set is designed to work on 120VAC. Therefore a 220VAC==>120VAC step-down transformer is needed to feed it. The onkyo has transformer inside, and it should get 120VAC; atleast 5AMPS current capacity. AN inverter cannot synchronised with this set. You can either buy it from Inidan electronics spare part market, of can be winded by expereiced transformer winders. Never give any inverter to this set, as some Onkyo models will have Torroid transformer inside, and it will take a tremendous amount of current at start-up, and make either your Onkyo of your converter to get damaged. OK.
Jun 13, 2011 | Onkyo HT-S6300 Theater System
Have a Denon DN-C635 CD player . Replaced motor spindle / laser assembly (plug and play part assembly from Denon $45 old price $151) It loads disc , voice coil moves laser lens up and down but spindle...
Dave, Holding the motor spindle / laser assembly in a position where the white ribben plug in receptacle is facing in an upward position, look down to the lower left hand corner of the print board just under the plug in. You will see a small blob of solder bridging two contact points. Remove this solder bridge. I have found two new Denon assemblys with this problem.........*****
Mar 11, 2011 | Denon DN-C635 CD Player
Denon DN-600F CD player. The LINE OUT R
yes they need unsoldering from the board and new replaced if needed but you should be able to solder the ones that are already there just check for loose connection on them
Mar 25, 2010 | Audio Players & Recorders
No power to decks
sorry to say but you may have destroyed the units. USA uses 110volt. Uk is 240volts. There may be circuit protectors, pico fuses, internal fuses, and transformer fuses that have failed. replacing them first is the first approach to getting them going again. An adapter plug is not what you need. You require a step-down transformer to reduce the voltage supplies to 110volts. Check on the units also. There may be a voltage selector switch that you can select the right voltage for the UK. Be careful with how you go. Mains voltage kills. If you are not sure then please go to a tech and have them check the decks over for you. Good luck
Jan 31, 2008 | Audio Players & Recorders
Denon DN-600F CD Player Logo
252 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
