Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
Refrigerator makes lot of noise
The refrigerator makes huge noise momentarily (30-60 secs) at 10-15 minutes interval but it cools ok and make ice too.sometimes it is hard to sleep at night due to the noise. condensor copper tubing at the bottom of the refrigerator was covered with thick layer of dust which i cleaned using vacuum but didnt help. pl suggest possible remedy.
  • 3 more comments
  • simbachip Feb 04, 2008
    My refirgerator makes a loud clanging noise,2-3 clangs, when it shuts down. A repairman suggested the compressor is going. The fridge is only 9 yrs. old. What's your opinion? Time to shop for a new one?
  • wendykline1 Mar 06, 2008
    we have a very loud noise coming out of the back of our refrigerator
  • Pywacket1952 Jul 13, 2008
    lots of noise and a shuddering end to the noise. all else good.
  • darealzg Dec 12, 2008
    Mine is a year and 4 months old GE refrigerator, and does exactly the same thing you described. The sound seems to come out from the back of the refrigerator. All else work fine. I don't know if I should be concerned. The noise bothers me a lot.
  • sheldon_hu Feb 18, 2009
    My GE Profile Refrigerator makes big noise when the condenser is shutting down. Cleaning of the radiator grill did not help. The cooling is OK so far
    Problem Solver:
  • 5 Answers
Dear Titu,
I have the same problem with your refrigerator. It was making noise periodcally.
I have just fixed it. This noise either produced by uneven fan or fan motor. This fan was designed for cooling down the thermostats.
I took the fan off and spined it manually. I heard the sound like car belt. You can check right behind the fan. You will see the metal stick from the motor to the fan. Then you can use WD1040 oil to spray onto the surface of the metal stick which is hook up to the motor. This noise is produced by dried condition between the the metal stick and the ring which use to hold the metal stick and the fan. Goodluck
Posted by Chieu Nguyen
Posted on Feb 08, 2009
New Kenmore / Whirlpool, 25 Ft. side x side. Has drumming noise when running. Checking showed that condenser coils rattle against compressor support rails plus the flimsey rails allow compressor vibration which resonates through out. Looks like Whirlpool cost-cutting crossed the line over to plain old cheapening the product. Waiting on Sears to come check it. Wish me luck. -JT
Posted on Nov 21, 2008
I have a Kenmore that is 3 years old and only just started making a loud knocking sound recently. It is very annoying and lasts for 30 seconds or so every hour or two. I took off the back panel and found that if I shake the compressor tank something inside bangs against the wall of the tank. So I leveled the fridge a little better and the frequency of the banging sounds have been reduced significantly.
Posted on Feb 18, 2008
    President:
  • 878 Answers
Titu, can you be more specific on what kind of noise you're hearing. If it's a squealing noise I would suspect either the evaporator or condensor fan. See if you can isolate where it's coming from. Catriver..post back.
Posted on Oct 12, 2006
SOURCE:
My Hoover Frost Free A class HTK 95AA has a trickling water noise coming from the back around the cooling pipes when switched on. The compressor gets very hot although the cooling pipes do not, is it
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Kitchenaid refrigerator making rattling noise
YOUR ARE GETTING ICE AROUND YOUR FREEZER FAN BLADE THAT IS THE NOISE YOU ARE HEARING IT COMES FOR THE ICE MAKER FILL TUBE THAT COMES IN FROM THE BACK WALL OF FREEZER TO THE ICE MAKE YOU CAN'T DO ANYTHING TO FIX IT JUST MAKE SURE YOU HAVE NO ICE BIULD UP IN THAT TUBE IT MAKES IT LEAK DOWN ON YOUR FAN
Oct 30, 2012 | Refrigerators
My refrigerator is not cooling the freezer works
We have this refrigerator and what you described is a chronic problem. (I hate this refrigerator!) Our repairman got tired of hearing from us so often and told us how to fix it ourselves! Take everything out of the freezer side and unplug it. Remove the white back part inside the freezer part. There are 2 screws at the top. The inside will be full of ice. Melt the ice with warm water. It makes a huge mess so get lots of towels. Once all the ice is melted you can put everything back and plug it in. It may take a day for it to get really cool again. My long term advice is to get a new refrigerator...
Jan 05, 2010 | GE Refrigerators
Coolong fan making a lot of noise
There are probably at least three fans in your refrigerator. I am assuming it is the fan in the refrigerator, check to be sure it is not being obstructed with ice or some other alien matter. If it is clear then you need to order a new fan ASAP. While you are at it check the condenser and condenser fan, they both probably need cleaning.
Good Luck,
Gilshultz
Nov 29, 2009 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Jun 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Dec 27, 2008 | GE Refrigerators
Whirlpool Side by Side not cooling, not making ice,
your start system is out on the compresser you wil need to replace it you can get a factory oring. or uy a gernic kit like a Supco Pro-41 it will fit all ref. at half the price
May 10, 2008 | Refrigerators
based from your story. the noise could be coming from the compressor as it starts. compressor usually vibrates a lot when starting. it would last from a few seconds to a few minutes then would normalize as it sucked all the evaporator pressure down to its normal readings. you can check the rubber mountings of the compressor,you may need to replace them. also check for some tubings that may be rubbing or touching as the compressor vibrates. tighten alllso those mounting bolst of the compressor. that should solve your problem. if everything is done and still the same, the noise could be coming inside the compressor which there will be no solution but to replace the compressor. the cleaning that you did helped it a little bit because the vibration decreased a little coz it was able to breathe a little.
Feb 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
1,170 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Paul Carew
Lawrence Oravetz
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
