Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Fridge freezer problem
I have a Candy ff and while the fridge is working normaly teh frrzer is now acting like a fridge. Hence its cold but not freezering. On the top of the ff the green light is on but the other red light is off. Hope that helps
    Master:
  • 363 Answers
Hello, everyone, have you ever played a game called RuneScape? I heard this game is very popular before, and now there are still many players, and recently I found a website may be able to help you, to share with you www.rsgoldfast.com
Posted on Dec 28, 2016
    Scholar:
  • 60 Answers
Your appliance needs to have the condenser area cleaned or it is low on freon. Call a repairman to look into it.
Posted on Nov 06, 2008
Candy fridge freezer not cooling in fridge compartment but freezer working ok
Check to see that fan in back of freezer is running. That's what pushes cold air into fridge.
Aug 04, 2013 | Candy Refrigerators
Fridge section is too cold causing food to freeze
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 03, 2009 | Refrigerators
The fridge of my candy fridge freezer is far to cold and almost freezing goods,the fridge is set on the recommended number
check to see if the coils underneath the fridge are clean. It seems more like an airflow problem. The chances of the fridge being under or over charged with refrigerant is not likely ..
Nov 15, 2009 | Candy CPCA240FFK Bottom Freezer...
Fridge not cold enough, Freezer ok
The refrigerator gets its cold air from the freezer section through ducts and damper control. Check for blockage.
Apr 27, 2009 | Candy CPCA240FFK Bottom Freezer...
Fridge running light(green)flickering
hi,thanks for your e-mail i couldn't find a solution and the fridge was fairly old we bought a new one,cheers,vic.
Nov 30, 2008 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
Candy CPC 290 FF
Hello
Well the sheet of ice was caused by the thermostat failing and causing the fridge to continously run therefore causing the over freezing..
Like a car engine if you leave it running for weeks on end without stopping it probably will burn out...
Or like a horse is you have it working day in day out with out rest it will die..
you compressor on your fridge is no more... it ran and ran and now its all worn out .....
The clicking noise at the back of the fridge is the compressor trying to swtich on but it can't
only a professional can legally change over the compressor
as it is a techincal process recharging the fridge with gas
if you need any other help let us know...
you need a new fridge by the way
Jan 10, 2008 | Candy CPCA270FFK Bottom Freezer...
i have candy fridge freezer which the thermostat is on high setting but not cold as it should be. There is build up of ice around thermostat at the back of fridge inside. What is needed to repair?. Any ideas? Cheers!
Nov 02, 2007 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
197 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
