Question about Dryers
LG TROMM DLG9588WM Dryer: when i turn power on it says clean filter, filter is clean. when i select settings and turn dryer on it says simultaniously drying on and cooling on. read manual but can't find anywhere what this could be. any help would be appreciated before i call repairman. thanks
  • 4 more comments
  • Yxat Nov 06, 2008
    I have the same problem with my 1 yr old LG Tromm DLE7177WM electric dryer. There is nothing in the filter and the duct is brand new. In addition to the sensors remaining 'on', there is no heat coming from inside the dryer, no matter what setting I put it on.
  • ohioriverluc Dec 01, 2008
    we are having same problem have checked lint trap took off the top the cooling light stays on
  • Anonymous Jan 25, 2009
    Our LG Tromm dryer does exactly the same thing. "Dry" light flashes but while running and "cooling" light stays on. Clothes take forever to dry.
  • wookster Jan 28, 2009
    Same issue here. Cooling light never turns off (hasn't since we bought it only 2 months ago) Now the timer jumps time and is doing weird things.
  • ODeaEMT Feb 03, 2009
    We are having the same problem, our dryer is about 4 years old and it just started doing this today. Has anyone had any luck figuring out what is going on? Thanks!!
  • aljenkins Apr 22, 2009
    I am having same problem...dryer is less than one year old. Check Filter light comes on when I power it up. No matter what setting I choose, the Cooling light stays on and no heated air comes out throughout the entire cycle. Please help!
I checked the gas valves. One was bad, so I changed the pair. They only come in pairs. Now my dryer works with the proper heat, but the cooling light still remains on.
Posted on Nov 20, 2009
Help my dryer is doing the same thing. Clean Filter, it's clean. Now just won't run.
Peg
Posted on Mar 05, 2009
How to clean the pump filter on an LG tromm
Do you have the manual for the washing machine. This is documented in the manual.
Sep 01, 2014 | LG Tromm Front Load Washer And Dryer Set
Dryer won't heat
Your machine may have a bad sensor. go to your computer and type in the make of the machine add troubleshooting. you should have a selection of sites to visit. Usually the fix is simple and You Tube has many video's available that you can view that give you step by step instructions on fixing the problem.
Nov 30, 2013 | LG Tromm Front Load Washer And Dryer Set
LG Tromm Dryer Won't Stay On!
Your motor might be weakened. As when you start is back does it come on if it does then we are looking at venting issue.
Oct 06, 2017 | Dryers
LG TROMM DLE7177RM Dryer: when I turn power on it says Clean Filter, filter is clean. when I select settings and turn dryer on it says simultaneously ''DRY'' flashing and ''COOLING'' on -- it ends up...
Ah you unhooked it from the wall, but did you go outside and see if air flow was adequate outside. Quite often flexable hoses and duct work get plugged with lint. If that is the case be glad your dryer had pleanty of safetys. If you start it briefly with the hose disconnected, do you get the dry light flashings? Metal duct work all the way outside is best.
Jul 11, 2010 | LG Dryers
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
LGDLE0442W Dryer check filter light on. Flter clean dryer sounds like it wants to start but doesn't. Is there a reset button?
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | LG DLE2514 Electric Dryer
Check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Dec 23, 2009 | LG Dryers
Everytime i turn on my lg tromm it says check filter
TRY TAKING OFF THE VENT HOSE AND RUN A CYCLE WITHOUT IT AND SEE IF IT DRYS FASTER....YOU MAY HAVE A CLOG OF SOME SORT IN YOUR WALL
Jun 23, 2009 | LG DLG5988 Gas Dryer
Dryers Logo
905 people viewed this question
Top Dryers Experts
