Question about Canon PowerShot S70 Digital Camera
Flash Operation Flash not operative. Battery OK. Infra-red light works
  • Anonymous Apr 24, 2009
    no flash. everything else is great. disappointing
Is the battery cover cracked or broken?
Posted on Nov 07, 2008
My TV remote won't work the red light flashes and that's it
On your mobile camera and place the infra red LED in front of your camera...and press any button of your remote. if you can see the infra red light in your camera then your remote is OK and if you cant see the blinking light of infrared then your remote is out of order you need to change it
Nov 14, 2016 | Televison & Video
My remote is red light is flashing. I changed the batter and the battery in the unit is working. I can turn on the fireplace manually
  • The usual indication for a flashing light is a low battery. Suggest checking the remote again. Especially for corrosion at the battery terminals.
  • When you operate the remote will the receiver flash its LED indicator confirming that the command has been received.
  • The manual operation of the receiver located at the fireplace likely does not require batteries. For remote control operation good batteries are required.
  • If the red LED on the receiver is flashing the batteries need to be replaced.
  • If the LED at the receiver indicated that the command is received check the wires to the control valve from the receiver. The voltage is a very very low a millivolt signal.
Dec 01, 2015 | Heating & Cooling
When i insect the battery into the mouse will it turn on a light
not necessary.The optical mouses can use infra red or visible laser as a source.in case of visible source mouses ,after connecting the battery u can get red light when any surface comes in proximity.but in case of infra red mouse,although same thing happens ,but infra red is not visible to naked eye.
Oct 25, 2015 | Computers & Internet
The infrared eye has quit working - can it be replaced?
Are you sure it's the receiver infra red and not the remote simple check is to operate your remote and hold it in front of a phone camera if working you will see light flash.
Jul 02, 2015 | Jwin JV-DTV3212 32 in. HD-Ready LCD...
Hi. the remote control is not working .none of the keys working , just the pointer . the red light in TV is not blinking. we change the battery but still dosnt work.
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing each button on it at a time; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Apr 11, 2015 | Televison & Video
Why isn't my remote controlling my wwk-05crn1-b17 5000 ac unit? I have looked in both remote and A/C operating manuals.
Check the transmit LED is working on the remote by pointing it into the lens of a digital camera and pressing the power button. The camera will pick up the infra red flash if it is working. If it is OK, the receiver board may be shot, which is relatively common for air conditioners.
Mar 22, 2015 | Heating & Cooling
How to checking display is no timmer is light and power is flash remote control work no indicator ?
Contact any service technician. Your remote control should be checked for its infrared emission. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV.
Feb 04, 2015 | Televison & Video
Remote Control won't work with TV
Nothing was wrong with the remote in the first place! The problem is in the TV. Some use a sensor that sees the Infra-Red light from your remote, others use an IR phototransistor. The signal then goes to a controller that performs the required function. Check the IR sensor on the front of your TV first. You can confirm operation of your IR remote by pointing it at a camcorder with night-shot and pressing the button.
Jul 24, 2007 | Panasonic CT-30WX15 30" TV
White flashing screen & red light permanent
this complaint is probably software complaint so flash your phone
Jun 29, 2007 | Sony Ericsson K750
BLURRED PICTURE WHEN USING MOUNTED FLASH.
If you are not using canon lenses then the low light focusing aid will not work correctly. Go into the menu and turn of the flash infra red light
Jun 10, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon PowerShot S70 Digital Camera Logo
130 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
