Question about Canon Office Equipment & Supplies
Canon MP620 printer - i cannot get the printer head alignment to work. In particular lines F and G are continually out of line.
  • Canon Master
  • 13,433 Answers
Follow the alingment instructions on this file
http://koti.mbnet.fi/exuli/aling.pdf
Posted on Nov 06, 2008
    Master:
    Sergeant:
  • 461 Answers
Try hard reset the printer
1. Turn off
2. Remove power supply cable from the main switch
3. Leave it for about 30 to 60 sec
4. Restart again...
    Master:
  • 763 Answers
Try to configure it on the lever adjustment on the printer and also on the program that youll using to print your documents. you can set the width on it.
thank you for using fixya
CHARCOIS
Im trying to print an envelope from the rear tray and it continually says
i think encelopes are to thick.
try to set it in the midel of the tray
Nov 13, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Canon Pixma MP620 problem. It prints with a thick white lines going horizontally, so that the texts are faded out and not legible.
You probably need to run maintenance on the printer.
On the LCD do the following: (1)Select Settings on the HOME screen, and press the OK button. (2) Select Maintenance, and press the OK button. (3) Select Nozzle check pattern, and press the OK button. (4) Select Yes, and press the OK button. The nozzle check pattern will be printed and two pattern confirmation screens appear on the LCD.
This will tell you if the nozzles are out of alignment or not.Regardless you should not run the deep cleaning on the print heads. From the LCD do the following and make sure you have several sheets of paper in the printer;
(1) Select Settings on the HOME screen, and press the OK button. (2) Select Maintenance, and press the OK button. (3) Select Deep cleaning, and press the OK button. (4) Select Yes, and press the OK button. The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 1 minute 30 seconds. (5) Select Yes, and press the OK button. The nozzle check pattern will be printed. (6) Check the nozzle check pattern. See Examining the Nozzle Check Pattern. - If a particular color is not printed properly, replace the ink tank of that color. See Replacing an Ink Tank. - If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours. - If the problem is still not resolved, the Print Head may be damaged. Contact your Canon service representative.
Mar 05, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I am running a csss system on a canon mp 190 printer.My problem is that I am getting alot of lines in my prints,this has only started recently.I have cleaned and deep cleaned many many times and I have...
Assuming you have aligned the head to produce the minimum noticeable amount of white streaks and gioven all the cleaning, deep cleaning and alignment you have done there are two conclusions.
1. If the printer has been performing OK and using the same ink supply in the CISS and the actual printed results are OK then simply continue withthe setup as is.
2. If the setup as is is producing unacceptable results then you will have to consider changing the print head for a new one.
Oct 23, 2009 | Canon Office Equipment & Supplies
Canon MX700 printer - vertical lines aren't straight
Have you tried to do an alignment. Also check encoder strip
Aug 19, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Prints every other line
Use the cleaning cycle first.If it completes do a nozzle check and then to align follow below.
You need to hook it up to computer to do a manual head align through the printer properties maintenance section.
Jun 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
PRINTER NOT WORKING PLEASE HELP!!!!!!
Uninstall and reinstall the printer driver
S. Mohan
Mar 07, 2008 | Computers & Internet
old marine
old marine
