I have a Canon Printer MP620. I cannot get the printer head alignment to set up properly. In specific it is the lines F and G. They are continually offset no matter what i do. I can scan you the problem if you want.
  • ygor705 Jan 02, 2009
    Exactly the same problem here. Print is fine but out of alignment on A4 printing from left to right. Fields F and G on the print alignment schedule are out of whack as well. This is a very weird set up procedure for head alignment.
    ygor705
  • 19,396 Answers
You need to perform the print head alignment from setup procedure, and chose the right alignment number after printing the pattern page.
Posted on Nov 06, 2008
  • Ginko
    Ginko Nov 06, 2008
    Do the alignment procedure several times, and try to chose the right pattern.
    If that does not work, then that means that the printer have a problem with the encoder strip that determine head position, in that case the encoder must be replaced.
  • 1,879 Answers
A scanned image is perfect. Please do upload it.
Software mp620
Here you can download drivers for Windows:
https://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/PIXMA_MP620.aspx?DLtcmuri=tcm:13-852997&page=1&type=download
There is no specific driver for OpenOffice, once you will install driver above, your scanner will work will any office product.
May 11, 2014 | Canon Computers & Internet
Alignment on canon mp210 is off
You can try to do a power reset on the printer and if does the same, try to do a hardware reset. I found some steps on this site with specific error messages, How to reset Canon mp210. It has steps procedure you can follow.. :)
Aug 15, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma MP620 problem. It prints with a thick white lines going horizontally, so that the texts are faded out and not legible.
You probably need to run maintenance on the printer.
On the LCD do the following: (1)Select Settings on the HOME screen, and press the OK button. (2) Select Maintenance, and press the OK button. (3) Select Nozzle check pattern, and press the OK button. (4) Select Yes, and press the OK button. The nozzle check pattern will be printed and two pattern confirmation screens appear on the LCD.
This will tell you if the nozzles are out of alignment or not.Regardless you should not run the deep cleaning on the print heads. From the LCD do the following and make sure you have several sheets of paper in the printer;
(1) Select Settings on the HOME screen, and press the OK button. (2) Select Maintenance, and press the OK button. (3) Select Deep cleaning, and press the OK button. (4) Select Yes, and press the OK button. The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 1 minute 30 seconds. (5) Select Yes, and press the OK button. The nozzle check pattern will be printed. (6) Check the nozzle check pattern. See Examining the Nozzle Check Pattern. - If a particular color is not printed properly, replace the ink tank of that color. See Replacing an Ink Tank. - If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours. - If the problem is still not resolved, the Print Head may be damaged. Contact your Canon service representative.
Mar 05, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I have a MP640 that is printing photos with lines across it. The ink levels are fine.
make sure you choose the proper settings when printing. use the correct paper settings on printing, the paper may be hitting the head while printing. if these lines are gaps, you may need to clean your print head using the software of you printer. make sure you also align your printer head especially if you have new inks. this will ensure the printing is how its supposed to be.
Jun 19, 2010 | Canon Office Equipment & Supplies
Blurry photos from Canon PIXMA MP620
Either ink cartridges or PRINT HEAD faulty
May 25, 2010 | Canon PIXMA MP620 All-In-One InkJet...
What is E7 on the canon mp160, and not working anyway..
When the head alignment sheet was not filled in properly Printer show E7.
  • Confirm circles on head alignment sheet are filled in properly MP160
Head Alignment Sheet The head alignment sheet was not filled in properly.Confirm the circles were filled in as follows:
Good example:
Bad examples:
If more than one circle is filled in, reprint the Head Alignment Sheet.
Print Head Alignment
  1. Ensure that the printer is powered on and open the paper output tray. (Confirm that the paper thickness lever is set to the left.)
  2. Load a sheet of A4 or Letter-sized plain paper in the auto sheet feeder (or ASF).
  3. Press the <Maintenance> button several times until [P] is displayed in the LED.
  4. Press the <Black> or <Color> button. The machine prints the head alignment sheet.
  5. From each group, select the pattern which has the least visible streak.
    Example of the pattern with the least visible vertical streak
    Example of the pattern with the most visible vertical streak
  6. Pencil in the circles on the left side of the selected pattern, using a dark pencil.
    < 1 > Good example
    < 2 > Bad example: Checkmark
    < 3 > Bad example: Line only
    < 4 > Bad example: Not dark enough
  7. Open the document cover and load the head alignment sheet on the platen glass.
    Note: - Place the printed side down.- Align the sheet with the alignment mark (shown by the arrow) on the lower right corner of the platen glass.
    05sj00115_06.gif Alignment Mark
  8. Close the document cover gently.
  9. Confirm that U is displayed in the LED.
    If U is not displayed, press the <Maintenance> button several times until [U] is displayed in the LED.
  10. Press the Black or Color button.
  11. The machine scans the head alignment sheet and aligns the print head automatically.
Feb 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I am installing an i860 printer and it will not align automatically nor print properly. How can I do the alignment manually?
You should have access to a set of utilities in your printer set-up panel. It's called 'Canon IJ set-up Utilitiy'
There is a complete list of jobs that can be done on this printer there.
It normally does the alignment routine when you first install the print-head and cartridges. Is this brand new or just new to you? If you have got it second-hand then logically it won't need an alignment doing unless the print-head has been changed.
Nov 29, 2009 | Canon i860 InkJet Photo Printer
Canon i455 not printing properly
(i posted this for someone before)
When you remove the black cartridge there will be electrical contacts inside the printer that lines up with some contacts on your cartridge, make sure these are clean
Also, according to this printers manual, have you tried a printer head align?
"(1) Open the Printer Properties dialog box. See Opening the Printer Properties dialog box directly from the Start menu
(2) Click the Maintenance tab.
(3) Click Print Head Alignment.
Follow the instructions on the screen."
Oct 31, 2007 | Canon i455 InkJet Photo Printer
250 people viewed this question
jasbo
jasbo
