Question about Indesit Dishwashers
Dishwasher indesit DIF04
My dishwasher indesitDIF04 (4 months old) ,won't switch off and the on/off button keep flashing with the -intensive wash button-.The dish washer make a funny noise as well.The filter are well clean and is draining normaly, what can it be than? thanks
  • 1462 Answers
SOURCE: dishwasher will not drain water out
if plumbed in under the sink, check the spigot the drain hose goes to is not blocked - a common problem. if on drain you should be able to hear the drain pump working. if you hear a faint humming noise instead, then there is probably a foreign object stuck in pump. also check for blockage in the drain hose
Posted on May 06, 2007
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
SOURCE: dishwasher issue
Have had this problem twice on my DWI614. First time engineer came out and I watched what he did and asked questions. He removed panel at bottom of dishwasher (2 screws) after removing facia panel from kitchen as it is a built in dishwasher. To the right is the drain pump. Remove 1 retaining screw and hose retaining clip. Ease out the drain pump and make sure to have some cloth beneath as residual water will flush out. Before I did this the second time I removed as much water from inside with a small cup first. Both times I had blockages in the drain pump. First was a piece of glass and second some food. I also pulled the drain pipe forward and blew through to make sure path to sink was clear. Clear out and reassemble. Start a simple program before putting the front back panel back on and you can touch the drain opump and feel it working as the water drains properly. That was my fix both times, good luck.
Posted on Jun 17, 2008
  • 126 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
Posted on Dec 30, 2008
SOURCE: The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Posted on Mar 11, 2010
Indesit DIF04UK: Help with problem determination please?
Modifying a wash cycle in progress:
If a mistake was made during the wash cycle selection process it is possible to change the cycle, provided that it has only just begun: open the door, taking care to avoid the escaping steam, and press and hold the ON/OFF button; the machine will switch off with a long beep. Switch the machine back on using the ON/OFF button and select the new wash cycle using the SELECT WASH CYCLE button; start the cycle by closing the door.
Dado
Sep 08, 2014 | Indesit Dishwashers
My indesit washing machine 12 hundred keeps flashing blue and red lights and won't do anything
Possible that the suspect could be the controller board, you can switch the machine off power for sometime, check the power outlet for the correct voltage. If not the front panel must be removed to check on the board and a possible fault of the processor or memory.
Feb 03, 2013 | Washing Machines
Indesit dishwasher wont come on
this might be a little late but i ahve the same problem, an indesit engineer has been and there ia a metal bar the control wires rub against when opening/shutting the door. major design fault if you ask me. it tripped my entire kitchen and extention out.
May 05, 2010 | Dishwashers
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Indesit DIF04 integrated dishwasher
Dishwashers normally are hot or cold feed.
My wife runs water at the sink to get it hot going in before turning on the dishwasher.
You can use either cold or hot water.
We have ours hooked up to the hot water side.
They work better hooked up to the hot water.
Mar 21, 2008 | Dishwashers
Dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit DV620
check your manual it should tell you what this code means and wether you can deal with it yourself
Nov 22, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwashers Logo
110 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
