The door appears to not be closing tight. When you use any fuction the steam from the food comes out between the door and the unit causing a great deal of condensation on the control panel. I believe the steam should come from the vents on the top. I just bought the house so I am not sure if this is normal. Is there a way to adjust the lock on the door? When the door is closed and latched you can pull teh door open about 1/8 inch or more.
No! this not normal, I'am concerned about microwave leakage, and a 1/8 gap is to much, should be tight against the seal "major safety factor" the door is out of alignment or the bottom latch is not secure "to much play" I recommend a pro simply because he needs test for leakage when the door is properly fixed.
SOURCE: After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
SOURCE: Active Vent opens and closes continuously while unit is idle
My GE Profile active vent keeps opening and closing while the microwave is idle, too. I don't know what to do, either!<!-- from fixya rte -->
SOURCE: Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
