SOURCE: fridge freezer exposed to fire smoke and not cooling down
Sounds like you may possibly have caused some damage when you cleaned it up - can you talk us through exactly what you did to it and how badly it needed "cleaning" - was it caked in soot etc. How hot do you think it got during the fire? if it got much above 60 celcius for any length of time what can happen is that the refrigerant gas boils enough that it will overwhelm all the seals. only real way to check is get a fridge repair guy to test it for leaks and refrigerant content, be careful not to run it too much in case this is the problem - can be fixed but running it won't do it any favours. Hope this helps, please post back with a bit more detail and hopefully we will have more of an idea what the problem could be :)
SOURCE: LG LRBN20514ST Bottom Freezer Frig cooling problems
Unblockin vents....great....but is the fan blowing. It blows air from the freezer to the fridge in accordance to fridge temp you set. If you find this helpful, please post as such or go live chat for faster answers. TY
SOURCE: fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
47sdt
SOURCE: LG lfc23760 fridge is not
It seems that the compressor is not working. If so, then you must get the compressor to work first. If it is working then the feron gas may have leaked out. If so, then please get it refilled.
SOURCE: We just moved and now
Hi Check the freezer to ensure it isn't over loaded with food stuff; reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly. You should also check the coils on the rear of the refrigerator and make sure they are clean and dust free. If you still have problems after trying the above; you may need to call a repair service to come out and check the unit.
Please check this links to get a detailed idea as to why your unit is not cooling:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
http://www.applianceaid.com/frig_notcold.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
If there is no cooling
at all on the fridge section but the freezer works then it is confirmed that
the compressor and gas pressure is OK. Now shut off the fridge and leave it
powered off while you clean and check the evaporator for frost. If frost is
seen it is a good indication as the compressor is working with sufficient gas
within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen
in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and
fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours
for cooling to continue and the fridge to cut off . If not the auto defrost
timer, or the thermostat must be checked. Frost formation without defrosting
could block the air flow and so shut the air passage to the fridge. Also the
blower fan must work and if this is not working then the fan can be faulty.
Also a fault on the control unit is a suspect to non functioning of any one of
these components.
If defrost timer works but frost keeps forming check while the compressor shuts
if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and
make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
