Akai lct42z6tm Main Board Replacement
Hi, this is raytheonlisz. I saw your reply to my post:
http://www.fixya.com/support/t1056508-akai_lct42z6tm_still_broken_after
About my akai LCT42Z6TM's messed up picture. You said that you can help me with a replacement mainboard?
Thanks,
Raytheonlisz
SOURCE: Akai lct42z6tm
The "tv" you bought is actually a monitor, meaning you need a cable converter box to actually watch cable with it.
Posted on Jan 30, 2008
  • 62 Answers
SOURCE: Akai LCT42Z6TM HD 1080P TV
Yes - the four capacitors that are mentioned are the correct capacitors - call 800-726-4405 to verify the info. akai LCT42z6tm
Posted on Mar 29, 2008
SOURCE: akai lct42z6tm
I had the same corner squares/scrambled display problem in a set just over a year old (of course). It became completely unusuable and I was not looking forward to a repair bill of hundreds of dollars. After reading these posts, I opened the back of the set and took out the board with the connections on it. (FYI, the cable connections were all hot glued down, but this did not present a problem - a little wiggling and they came free. I also took lots of digital pictures to make sure I reconnected it correctly.) This board had the four capacitors (C280, etc) mentioned in this section. Since I have not had any experience with soldering on electronic boards, I found a friend of a friend who was a techie and he agreed to look at the board. He replaced the 4 mentioned capacitors - although he said they seemed to be fine. He did, however, also notice that capacitor C336 in the same area of the board was bulging so he replaced it. SUCCESS. The TV is again working fine.
So if you are reasonably handy with a screwdriver, taking out the board is easy and makes transportation a lot easier than taking the TV to someone. The cost of replacing a few capacitors on a board was minor, and in fact, if I hadn't found someone with electronic soldering experience, I would have given it a try myself. You may, however, want to check for bulging capacitors (indicating a problem) rather than just replacing the ones mentioned.
Posted on Jun 10, 2008
Thanks for the suggestions! I replaced the capcitors and now the TV woeks like a champ!
Posted on Nov 05, 2008
  • 3 Answers
SOURCE: Akai LCT42Z6TM still broken after replacing caps
You still need to replace C301. I can fix your mainboard if you need help.
Tom
Tommy@ruden1.com
Posted on Mar 21, 2009
Akai 4298 plasma....sound no picture, lost manual...any help?
Check the power supply board, Z-SUSTAIN board, Y-sustain board for blown fuses and caps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps
Jan 13, 2011 | Akai PDP4298 Television
Hi Ketch1 I have Akai LCD with same problems: TV has red light blinking when plug to power; TV don't turn on. I opened the back and checked all the capacitors and saw those 3 capacitors standing in a...
You need to do more torubleshooting, bad caps can look normal but they can have high ESR which are bad for switching power supply circuits.
Need to check the DC voltages, also try disconnecting the power cables to the backlights inverter board to see if it will come on normally isnce the light blinking can indicating it is sensing shorted circuits so it goes into shutdown/restart mode.
Please leave rating if it helps.
Sorry I cannot find free service manual for you.
Jan 07, 2011 | Akai LCT2721AD 27 in. LCD Television
My tv will not turn on after a outage
First off thanks for using Fixya.com Expert community.
Here are steps to try before chucking this tv in the garbage.
1. unplug the tv from the outlet if you have not already.
2. Plug it back in the outlet and try to give it the power button.
If those steps do not work:
Your going to need a new power supply (kinda expensive)
Click here for a replacement power supply about $90 bucks
I hope you find this site Very Helpful! Thanks for using Fixya.com
ED Aka rulds2008
Nov 27, 2010 | Akai LCT2715 27 in. LCD Television
Fuel line needs replacement . have line but cannot get it through hole in gas tank.
Watch the video.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you need the IPL post back (below) with a model and serial number.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 07, 2010 | Poulan ES350 16" Chain Saw
Akai LCT42Z6TM Problems. Help?
I'm working on one now. So far, I've found two capacitors on the power supply board bad, both 1000uf/16V 105 degree caps location EC9 area. Still have mild interference on the screen which seems to change with the type of video being displayed.. Will look for C301 next, is it on the signal board?
Jan 08, 2010 | Akai LCT42Z6TA 42 in. LCD Television
I have this akai tv model lct42z6tm and connected to a vcr video output to the video input of the tv.it works for about 2 minutes and suddenly it shows grayish horizontal lines and the it scrambled all...
You may have bad capacitors on the main board where the signal is processed. These caps are as labeled: c280,c323,c302 and c320- replace this one first (it usually fixes the problem) Replace these caps with 100uf @35V
Feb 21, 2009 | Akai LCT42Z6TA 42 in. LCD Television
Akai pt46dl10 lost the remote control
Stevenson
To tell you the truth I can fix any electronics equipment. But in your case because the dog break the digital printed board inside. you need to buy a new remote. I have one original remote for akai lct42z6tm that can work on your tv. If you really want the exact one I can get it for you. My e-mail address Stevebuy31@hotmail.com
Jan 05, 2009 | Akai PDP4225M 42 in. Plasma Television
Akai LCT42Z6TM only the HDMI input works
I have the same problem any solution yet
Apr 12, 2008 | Televison & Video
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
