SIGNAL BOARD FOR A PYROD 26"LCD FLAT SCREEN TV.SERIAL #:CX30 DG26 B.05.3544.11A
Coldcut
  • 1554 Answers
SOURCE: Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Posted on Feb 18, 2008
  • 280 Answers
SOURCE: Syntax olivia 26" lcd tv
One of two things. the digital board, or the display is going bad. if the display is the problem it probably is not worth repair. The digital board my not cure the problem an is expensive.If the lines are different colors it my well be the display.
Posted on Apr 18, 2008
SOURCE: No Display on screen of PHILIPS 19" PowerBass LCD Flat TV (190G6FB).
Tv philips no sound no volume only light
Posted on Jun 14, 2008
SOURCE: Venturer TV
to program the direct tv remote to any non listed device, press and hold the tv button until all lights stay lit, then press the small red tv power button, then press the channel up button repeatedly until the tv turns off, then press the red record button. may have to find the best code that wokrs all functions by repeating the above steps several times-
Paul
Posted on Jul 01, 2009
  • 7 Answers
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
Thanks for your help. as soon as i turn on the tv there are white lines across the screen that shouldnt be there. and the entire screen slowly fades to white at the same time as sections of the tv freeze...
Tv still have audio sound after it is turn itself all white on the tv LCD screen panel?Yes.Than this problems it is the tv main tv Tuner signal board it is dying and the causes.That the board,where the tv imcomming broadcasting signal cable wire plug into it.U have some skills,like can do some basic mechanicals works like take things aparts and putting it back together again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv main tv Tuner signal board for the replacement.
Aug 15, 2011 | Toshiba 26AV502U 26 in. LCD HDTV
White screen when I turn it on and only had it for 2 years. It's a Sharp lcd tv model# LC-26SB24U. Please tell me that its a defective part, like the tv tuner signal board.
The problem is that the t-con board is not receiving signal to the logic board or there is no supply coming to the t-con board. T-CON board gets the signal to logic board to produce image in to the screen if T-CON board fails white screen is produce. Try to check if there is a bulge up in the top of the capacitor. Note before opening the back cover of your tv be sure to unplug the unit feel free to send feed back good day and best regards.
Aug 14, 2011 | Sharp LC26SB24U 26 in. LCD TV/DVD Combo
Can hear sound but the screen is white
The tv Tuner signal board it is the causes and the problems,that the board where the incomming broadcasting signal cable wire plug into it.Fixed this problems before,many times before the small Mosfat 6 legs IC that regulator the voltages for the main CPU chip on the board it is dead that why the tv Tuner signal board it just have a blank and white tv LCD screen panel only have no video,but it have audio sound to the tv.This Mosfat 6 legs IC are surface mounted IC is very hard and almost impossible to replaced by a regular home soldering iron equipments,even if u somehow able to buy this Mosfat IC voltages regulater.If u have some mechanical skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.Will fixed this tv wright up.
Aug 06, 2011 | RCA L26HD31 26 in. LCD HDTV
My sylvania 26" lcd tv turns on for about thirty
Now the tv turn on,the tv have power and the LED power light indicator to the tv have stable power?Yes?Just a black blank LCD screen panel?Yes,than the only thing is wrong for this tv problems it is the tv Tuner signal board.That the board,where the incomming broastcasting signal cable wire plug into this board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 08, 2011 | Sylvania 6626LCT 26 in. LCD Television
Replaced backlight board, now screen is just white, no picture
Ur tv have only white screen with sound before?The LCD inverter board,that help for LCD screen panel to have backlight is not the problems.The tv Tuner signal board is the problems.That the board,where the incomming broadcasting signal cable wire plug into it.Repair this problems before.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Jan 11, 2011 | Element Electronics ELCHW261 26 in. TV
My TV has a white screen, but the sound is still there.
The tv Tuner signal board is the problems and the causes.That the board,that take in the incomming broadcasting cable signal plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 26, 2010 | Vizio VW26L 26 in. LCD TV
No Picture-white screen
Ur Tuner board,that the tv signal came into that board.U have a little manchanical skill.Take ur tv aparts.Replaced that Tuner board ur tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board to replacement.
May 11, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
The tv turns on with sound but the screen is just white
Ur tv Tuner board is dead.Replaced the Tuner board,u will get ur incomming cable or free air tv signal go through and get ur tv picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
May 05, 2010 | Sharp LC-26D6U 26 in. LCD Television
Acer flat screen tv - sound no picture?
Acer AL2671W 26in problems: (1) sometimes sound but no picture, (2) or screen freezes pink etc. (3) or remote won't turn it on/off (4) or it gives up and says "no signal". Turning it off/on usually solves it temporarily.
Nov 17, 2009 | Acer AL2671W 26 in. LCD Television
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
