SOURCE: Iomega fat 32 formatter program does not allow me
If you really must have fat 32 (maybe for MAC use ?) then windows itself does not support doing a fat format on large drives.
However there is a fix Yup thats why they call it FIXYA
Here is a link to just what you need
Hope its what you need and good luck
SOURCE: I'm trying to format my Iomega 500gb ego so that I
you have to use an other HDD having OS on it... and attach other HDD and format it ..it will work!
SOURCE: Iomega eGo 1TB USB 3.0 Portable portable harddisk
Few different things are possibilities.
1. Are you connecting the device via USB 3.0 to the USB 3.0 adapter on the computer?
2. Try switching out your USB 3.0 cable for a different one.
3. If you are using the USB 2.0 instead. Make sure you are using the USB Y cable for the device and not just a standard USB 2.0 straight cable.
Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's
into the computer starting with the short side USB then the longer side USB second. Also try
using the USB's on the back side of the computer as they will supply more power than the
USB's on the front of the computer.
SOURCE: My HDD is locked (eGo
Hi ,
I think you will find the solution here : http://search.wareseeker.com/hdd-unlock/
Regards .
SOURCE: Hello support First of all
Your hard drive encrypts all the data put on it, so you need a password to access it. If you haven't changed anything, the default password should be just the word "password" I would recommend changing that as soon as you get into the drive. There should be a very obvious option in the program once you enter the password for the first time.
