Formac Gallery screen
I have the above monitor that i use with my Apple G5. I turned it on this morning and the computer booted fine making all the usual sounds, but the monitor stayed black ! The power light is slowly dimming and increasing in light, but there is no response when I move the mouse. Does anyone have any idea what's going on ? Thanks Al
  • algreen Nov 08, 2008
    Thanks for that. I found out what it was in the end, I had recently changed the disk drive in my mac and i'd dislodged a metal cover from the back of the mac that was touching the video card cutting out the image.
    New Friend:
  • 99 Answers
I think your monitor PSU is cycling on and off, may be the horizontal stage is faulty, either way u have to take it to a service tech
Posted on Nov 08, 2008
  • Rifaa-ath Razei
    Rifaa-ath Razei Nov 09, 2008
    hehe...glad u didn't damage the video card.
    Happy tht ur problem is solved, still if u post a problem next time. please give a few more details on any prior attempts, then we will be sure how to guide u.
    Cheers
    Rifaa
I need a new power supply for a formac 1900 monitor
I've got two and you are welcome to one if you pay pp plus a sensible offerI live in South London UK
May 19, 2011 | Formac Gallery 1900 Oxygen 19" LCD Monitor
Suddenly, after no previous problems, when computer (Mac- G5, older, not intel) started up in the morning, the monitor, although power light on, displays only black screen. Monitor is lcd Formac- not...
Try hooking it up to another PC first, but more likely to have failure in the power supply caps or failed inverter cicuits.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 01, 2010 | Formac Gallery 1900 Oxygen 19" LCD Monitor
My formac dvi monitor wont work as a 2nd monitor for my laptop
Try a monitor that has a vga output only, sometimes these laptops can't recognize the difference when there is a converter involved. It doesn't see the signal properly.
Try that and if a regular monitor works with vga then you know that monitor may not be compatible with that laptop because of the converter. You could also try another converter as well to see if that fixes the problem.
May 07, 2010 | Formac Gallery 2010 20.1" LCD Monitor
Power button lights up but screen stays blank
First you check the problem with monitor or cpu.you can check it by other monitor.after replacing the monitor it gives not display. then your monitor has any hardware issue.then you can repaired it from service center.
Mar 24, 2010 | Formac Gallery 1900 Oxygen 19" LCD Monitor
I have an iMac G5 2Ghz that when it start up you can only see video for a few seconds. I connected an external monitor and my iMac works fine but with its on LCD there is no video. I check the logic board...
Sir,
The iMac G5 and iMac G5 (Ambient Light Sensor) computers have a video out port located on the back of the computer, which will mirror video. Video mirroring means you can see the same image that is on the iMac G5's flat-panel display on an external monitor, television, or projector.
Using the video out port, you can mirror video with a compatible VGA display using the Apple VGA Display Adapter.
You can also use the video mirroring feature with a television or projector that has S-video or composite video connectors when you use the Apple Video Adapter.
Both the Apple VGA Display Adapter (M8639G/A) and the Apple Video Adapter (M9109G/A) are available separately, and are needed if you want to use your iMac with a VGA monitor cable, S-video cable, or composite video cable.
The video mirroring feature is "plug and play". Simply connect a VGA display, television, or projector to the appropriate adapter (see above), then connect the adapter to the video out port located on the back of the computer.
When you connect the adapter to the computer, the screen may refresh momentarily as the computer prepares itself for the new video output. The computer tries to match the resolution of the built-in and external display. If there is no match, the computer changes both screen resolutions and may black out areas on the built-in display in order to match the capabilities of the external display.
Important: To ensure that your iMac G5 automatically detects the external display or projector, be sure you plug the adapter into the external display or projector before you plug it into the iMac G5.
You can switch resolutions and frequencies for both the iMac G5 flat-panel display and the external display, television, or projector using Displays preferences.
Want to watch a DVD movie disc on a television that's connected to your iMac G5? Select a 720 x 480 NTSC (in the United States) or 720 x 576 PAL (in Europe and other regions) resolution in Displays preferences.
Tip: Because of the display limitations of most televisions, the images displayed on a television screen are usually not as high quality as those on the built-in display or an external monitor.
Thanks
Good Luck
Aug 21, 2009 | Apple iMac G5 Desktop
Backenlight inverter panel failure formac gallery 1900 oxyg
mine had the same problem, replaced the fuse with a T2.5 amp.
Ammeter gave a reading of 1.6A across the fuse pads so we shall see if its pops...
Aug 01, 2008 | Formac Gallery 1900 Oxygen 19" LCD Monitor
Gallery 1740 Trips out my G5
Right I got my formac monitor open by removing the Bezel, it's tricky but not too hard. The casing is suprisingly flexible and forgiving. The clips are backed by a double sided tape on all four edges. Start from the top and give the tape time under tension to come unstuck, it will, a bit like a plaster.
Oh yes, unplug before continuing.
Inside there are four HEX #4 (5/64 inch) screws holding the display inside the chassis. These can be removed, on the back side of the panel is the power/controller board. And remaining in the chassis is the Cold Cathode power board (long thin one on one side). This can be unplugged to get more range on the cables. (remember which way it goes in, I use a marker pen over the plug and socket to show me where to put it back) The Controller board has a number of power components. Firstly there are 5 power diodes, they all seem to respond properly under a meter in my screen. There remains one linear voltage regulator LT1117 and two 500Khz Step down switch mode regulators, LT1374. These devices are most suspect for causing the over current draw. Replace them if you can do this with ease. However most regulators have inbuilt protection. So it is also possible that a support component such as a resistor or capacitor has failed causing the other components to operate outside of their intended parameters. I will post some pics of the board later.
Dr Matt
Feb 24, 2008 | Formac Gallery 1740 Oxygen 17.4" LCD...
Formac Gallery Monitor
Looks like the water is getting in to the LCD contacts. Or corroding them. If the monitor can be opened safely open it and place in a warm dry environment for a few days. Silica dehumidifiers may help.
If the issue is not permanent this may fix it.
Jan 27, 2007 | Formac Gallery 1740 Oxygen 17.4" LCD...
Computers & Internet Logo
411 people viewed this question
David Payne
David Payne
