Question about LG 32LG30 32 in. LCD HDTV
What size fuse for 32lg20
Fuse does not show continuity
    Top Expert:
  • LG Master
  • 14,553 Answers
The value of the fuse should be marked on the board under or next to it and also on the metal ends of the fuse.
Take care when replacing not to exceed the amp rating of the fuse and get one from LG (set is posted as LG) and not from Radio Shack etc.
Most of these are special fuses so some "generic" fuses may just pop for no reason.
Look on fuse and board for something like 5A 120 ac which is 5 amps and up to 120 volts out of wall(a 250 volt is also fine--you cannot exceed the amperage but it is ok to exceed the rated voltage.
I would suggest you buy at least 2 fuses just to have a spare.
Posted on Mar 22, 2012
SOURCE:
Dryer tumbles no heat
remove the top cover,then the front cover,then check the burner tubes ignitor or glo-bar that ignites the gas,the high-limit thermostat on the burner tube for continuity,the thermal fuse and cycling switch on the blower housing both of these should show continuity or good like a standard fuse would show
Nov 18, 2010 | Kenmore 74642 Gas Dryer
My electric dryer is not blowing heat, just cool air. What is wrong with my dryer.
Check the following to address this issue.
1. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 23, 2009 | Amana Dryers
My microwave no longer heats anything
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Aug 29, 2009 | Microwave Ovens
Does'nt heat up
Aug 05, 2009 | Samsung Microwave Ovens
IT RUNS BUT DOES NOT PUT OUT HEAT
Check the following to combat this issue.
Heating element
Thermal fuse
Jun 19, 2009 | Hotpoint NVL333EY Electric Dryer
My whirlpool duet dry isnt heating the laundry.
Jun 15, 2009 | Whirlpool GEW9250 Electric Dryer
My dryer isn't heating, but runs
Heating element
Thermal fuse
Jun 13, 2009 | Whirlpool LER4634J Electric Dryer
I have a Amana DLE330RAW everything works, but it won't heat?
Jun 13, 2009 | Amana DLE330RAW Electric Dryer
93 ford explorer xlt
First check your 4 wheel drive switch to make sure it works, for on an off settings. (Use a volt-ohm meter for this. On should show continuity in the readings (if digital then it should show zeros in the dial) Off should show no continuity or 1.0 in the dial.
1. Check your fuses.
2, IF OK, then check your FUSE LINKS.
3. IF OK, then check your 4 Wheel Drive relay in the fuse box.
4. IF OK, then check continuity of the wires harness to the 4 wheel drive switch for DC voltage.
Jul 26, 2008 | 1994 Ford Explorer Limited
DS Lite F1 fuse replacement
You have to carefully dissasemble the console, take the circuit board out and find the fuses.
Then test the fuses using a continuity tester, DMM or something alike.
A fuse must show electrical continuity, or closed circuit if good and shows a open circuit if bad.
WARNING NOTE: there are not high voltajes or currents inside a small battery operated device but the same way even static current is enough to make damage in the circuit.
If you dont know how to test a fuse you might make more damage than repair.
Good Luck...
Apr 20, 2008 | Nintendo DS Lite Console
LG 32LG30 32 in. LCD HDTV Logo
125 people viewed this question
RONALD CARTER JR
