Rx420 printer. On replacing the magenta cartridge, the printer will not work. It does not seem to see the new cartridge, so I put the old one back in but the same fault remains. I would appreciate your thoughts with thanks Anthony
  • tornado tony Nov 08, 2008
    rapanSF. Thank you for trying. I rang the ink supplyers and they were aware of this problem. It turned out to be a dodgy cartridge which they kindly replaced. Tornado Tony
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Something might be clogged or printer head needs replacing is my guess.
Posted on Nov 06, 2008
Hp c6180 states cartridges missing or damaged
OK now this might seem bizarre, but did you go ahead and click the "Black Only" print option?
I have a C6180. Just installed all new cartridges. Tried to print and got the message that Cyan is empty. Tried all sorts of things. Then out of frustration clicked the Black Onl option. Document came out printed in color! Double checked with a picture that has lots of cyan colors. It all printed too! Go figure.
Apr 25, 2012 | HP Photosmart C6180 All-In-One InkJet...
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Replaced yellow and Magenta to receive replace messages for both.
yes you reset your printer resume button press 2 times then solve your problem inshallah
Aug 12, 2009 | Samsung CLP-510 Laser Printer
Problem with printer
Have you tried a new magenta cartidge. I think it has run out, that'swhy you can only print black
Mar 23, 2009 | Canon imageRUNNER C3200 Color Printer
RESTART Printer
The new magenta cartridge you put in is bad. If you put the old one back in then you get the low toner message. Take the new cartridge back and get another new one.  I found the answer on the dell troubleshoot website
Feb 03, 2009 | Dell 5100cn Laser Printer
HAVE PUT TWO KNEW HP INK CARTRIDGES IN (MAGENTA)AND PRINTER SAYS (MISSING OR DAMAGED BUT THEY ARE NEW ONES. IT ALSO SAYS REFER TO PRINTER DOCUMENTATION ..I DONT KNOW HOW TO
1) NEED TO KNOW WHAT MAKE AND (MODEL) OG LASER JET THIS IS BUT MOSTLY THIS KIND OF TROUBLE IS CAUSED BY A BAD CHIP ON THE TONER CARTRIDGE OR THE SENSOR IN THE BACK OF THE PRINTER IS BAD OR BROKEN.
THE MAGENTA AND THE YELLOW ARE THE MOST COMMON
Nov 04, 2008 | HP Office Equipment & Supplies
HL-4040CN don't show or read new refilled magenta cartridge.
If you have removed and reinstalled the magenta cartridge several times, it is very likely the cartridge is defective out of the box. If you have another magenta cartridge, put that one in and see if the problem resolves. I'm betting it will. If that second cartridge does work, then return the defective cartridge to where you purchased it - they should replace it without a hassle.
May 10, 2008 | Brother HL 1440 Laser Printer
Epson R1800 printer won't recognize new ink cartridge
You can remove magenta & double check that some tape was not left behind on the contacts. Take a clean ragg & dampen it with alcohol. Clean the ink cartridge's (copper contacts & inside the the ink carrige). Re-install the magenta, (tight fit). Power off the printer. Wait a few seconds & power it back up. If it fails a second time with no other errors. Like the above. Than the magenta may be defective. Have a recipt? Return it for a replacment.
Feb 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printer says I have duplicate Magenta cartridges when I don't?
I think it's the chips on the cartridge - the colour that it thinks it's duplicating! I took it off the black (duplicated) and put it on the magenta and it thought it had duplicate magenta cartridges!!
Jan 19, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
114 people viewed this question
k24674
jasbo
jasbo
