Question about Zanussi Washing Machines
Can't open washing machine door. - Zanussi Washing Machines
  • 135 Answers
This is usually caused by the machine not draining properly. have you checked the filter behind the flap on the front of machine?. be sure to tilt the machine back before doing this!!! or better still disconnect and take outside.
Posted on Nov 06, 2008
My Bosch AvantiXX front load washing machine has finished the wash and now it has locked on me and I can't open it. How can I open the door?
hi Suzanne.
i have had a look around the internet and found that there is lots of ways to try and open it.plus there is people on youtube showing how to open a door.
so if you go to this link and pick the one you think would be the best one for you to try.
Bosch AvantiXX front load washing machine door wont open Google Search .
or this one.
How to open washing machine door that won open normally
Nov 20, 2017 | Bosch Washing Machines
My basch front loader door will not open after a wash cycle
How to open a washing machine door that won't open normally ...
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique on how to open a washing
Mar 22, 2017 | Washing Machines
My front loader washing machine won't open-the lock symbol disappears but despite putting the machine through a variety of cycles I can't unlock it
How to open a washing machine door that won't ... - YouTube
? 3:57
Your washing machine door won't open this video will show you a technique ... to our channels social media as this really helpsmy site and keeps us going. ..... Front Load Washer Door Latch Troubleshooting Replacement ...
How to Open a Washing Machine Door that's Stuck Closed ...
? 1:30
https://www.youtube.com/watch?v=s-_x2tSmd0A
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF If your washing ... of thumps on the frontpanel next to the lock to see if this shocks it to release. ....impossible for ariston av51 washer, my arm cant go thru it...small space for ... How to open a washing machine door that won't open normally.
How to open a washing machine door that is stuck shut.
www.how-to-repair.com > ... > Door Locks & Switches
Jan 04, 2016 | Beko Washing Machines
WHAT shall I do when the error LE comes on Dawoo washing machine? Tnx
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
  • Close the door!
  • Check the door lock switch
  • Check the door latch
  • Check PCB
Dec 06, 2015 | Washing Machines
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
? 3:57
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Handle broke off
? 3:57
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
https://www.youtube.com/watch?v=UCJPkc_dTCE
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
I have a daewoo washing machine dwd-g20dl showing error code LE
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
Washing machine door wont open - hotpoint
Never reach inside the washing machine with it connected to the mains. The door interlock is always live.
There are several reasons why a Hotpoint door could be jammed shut.
•A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
•If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
•A faulty door interlock
•The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thanks for contacting fixya.com
Nov 07, 2009 | Hotpoint First Edition FEW12 Front Load...
Cant open door of washing machine
I plugged it out. Left it for 15 minutes. When I went back the door could be opened and it also started to wash.
Jan 20, 2009 | Ariston Technologies AWD121WH
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Jul 19, 2008 | Washing Machines
Washing Machines Logo
95 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
