Question about Sony Walkman Bean NW-E307 MP3 Player
My player does not connect to pc...........
When i put the usb in the usb port it does connect with it......... i have  checked the usb port its ok..but there is some problem in the usb port of the player...so wat should i do...plz help me guza...it also not charge to...simply say it does not get the usb power to it when i connect it to pc..
Take to sony store. They replace it for a small fee
Posted on Dec 06, 2008
Mp4 player not working
Check your MP4 player's system requirements.
Some MP4 players are only capable of working with certain operating systems and hardware, so refer to your player's documentation to ensure it is capable of functioning with your PC.
Change the USB port your MP4 player is connected to if you have confirmed your PC can function with your MP4 player.
Disconnect other USB devices, and try connecting your player to another USB port if you are still having problems.
Try restarting your PC if it is capable of working with your MP4 player.
Restarting your PC resets non-functioning USB ports, which may be your problem.
Make sure your USB cable is connected properly.
If your player requires you to install drivers, make sure you install them.
Try connecting your player to another PC to see if the new PC recognizes it.
If it does, chances are your computer does not support the hardware necessary to run your player.
Reset your MP4 player if your PC is still unable to recognize it.
Resetting your player varies depending on the manufacturer and model, so refer to your player's documentation.
Contact your player's manufacturer if you are still unable to get it to work with your PC.
http://applestore.altervista.org/mp3mp4.pdf
Aug 25, 2013 | Intel Computers & Internet
Downloading Songs From PC
Mp3 player should have a USB port or a USB date cable, and what you need to do is using this port or cable to get connected to your pc, then when it appears in your pc, you can put songs in it. It's easy.
Get a Tablet pc as a gift for you and your friends!
Jan 08, 2012 | Philips SA1MXX04P/02 GoGear Mix MP3 Player
Sony mp3 player won't charge using any usb port in my computer. Mp3 port is loose...took apart, don't see y it's loose
Possible reason could be frequent use would have damaged the port connectivity, If there is another usb port use them or else you can clean them to se it this works. if not try to fix a USB extender which can be procured from any PC harware shop that might sometimes give a good connection , thre after do not remove this connector but use the extender port.Check to also see if your USB drivers can be reinstalled, check though the device manager/ ports. Helpful? Good day.
Jul 05, 2010 | Sony NW-A605 (512MB) MP3 Player
Mp3 player won't charge on my pc... how do i fix that?
Check the Following Instructions:
1. Check USB cable properly connected to the USB port.
2. If cable not connected properly or cable break, It should be not connected or not charge.
3. Change the another USB Cable, If problem presit, check ur PC USB Port.
Apr 11, 2010 | Samsung YP-K5 MP3 Player
Problem of player
  • Try to connect the player to the USB port at the back of your PC if you connect the player to the USB port in front of your PC.
  • If a USB cable is needed to connect the player to your PC, use another USB cable and avoid the USB cable that is too long.
  • Uninstall the player and USB drivers from your PC and re-install them.
  • Nov 11, 2008 | Philips SA5125/37 MP3 Player
    Hanging problem
    ya u are rite connect the cable thr will show that mtp connected then transfer music but is it hanged on than this means ur usb port has problem than try to use different usb port...make it sure u are using rear usb port of ur pc.....hanging problem is only due to breakage in transfer of data that is only due to low usb port...i have same problem i always connect my media player in front usb port of pc then i got to know that it has low speed than i connect it to rear of usb port in my pc that is high speed port than it worked smoothly
    Sep 02, 2008 | Samsung YP-K5JAB MP3 Player
    Hmm...well wnhen ever i charge my mp3 and i connect the usb with my computer then it doesn't show up anything in ma computer itz connected ornot n thats why i can't put new songs in it..
    Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
    Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
    Jul 05, 2008 | Mpio Audio Players & Recorders
    Windows vista does not acknowledge Opal M4002a
    If the player is not recognize try to connect the mp3 player ona different usb port and check if it will be detected if still not detected better connect this mp3 player to another pc and check if it will be detected on that second pc if not detected there's a possibilty that the mp3 usb functions is not working fine.
    Jun 20, 2008 | RCA OPAL M4001 MP3 Player
    IPod Shuffle and compatibility with USB ports
    yes it's a common problem, it might be a usb 2.0 or high speed usb port but the motherboard is unable to supply enough ampage to supply the port. Assuming you have tried removing other usb connected peripherals and tried a different port, the only way you may get the ipod to connect is to purchase a mains powered usb hub as the power supplied is sufficient to connect to ipods and pda's etc.
    Sep 10, 2007 | Apple iPod shuffle MP3 Player
    Elio doesnt connect
    i have similar problem, i think i know why mine doesn't work. My son connected the usb port to power supply, since then the elio manager does not recognise that the player is connected.... something must have blown in the usb circuitry
    Jan 29, 2007 | Tatung Elio Photo JukeBox MP3 Player
    Sony Walkman Bean NW-E307 MP3 Player Logo
    76 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
