Technosonic LCD26031D will not power on ... have checked supply is ok ... is this a known problem with this TV ?
  • WitneyJeff Apr 05, 2009
    Same problem, I think it may be the on/off switch as it makes a buzzing noise sometimes when operated.
  • Anonymous Apr 20, 2009
    Does not power up. Also, on off switch faulty and remote useless. Only 18 months old!
I have had the same problem with 2 of these TV's. The mains on off rocker switch goes faulty, open circuit. I'm trying to find supplier of replacement part.
Posted on Apr 25, 2009
Model KDL32BX300. Why won't it turn on?
PLEASE CHANGE THE INVERTER BOARD BECAUSE YOUR 24 VOLTS ARE SHOTED
Dec 20, 2015 | Sony Televison & Video
Technosonic LCD3251 TV remains in standby
Sounds like a signal board issue to me.... If your power supply lines are fine.... Seek a good one on EBAY or shopjimmy.
Feb 16, 2014 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
A MANUAL FOR TECHNOSONIC LCD2001 TV
ask here for the manual, they have already listed it on their site:
http://manualfox.com/link/technosonic.htm
Sep 12, 2011 | Televison & Video
Technosonic lcd2017d stand lost
Hi I have a technosonic LCD3251 tv and am trying to take the stand off, as it is wall mounted now, i have taken all the screws out but i still cant get it off!! D you remember how you took yours off?
Jul 26, 2010 | Televison & Video
Technosonic lcd19031d will not switch on , red light on front panel continually flashing
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Oct 22, 2009 | Televison & Video
Berndulay@yahoo.com
Accroding to your model number:(KV-...) In sony tv units power supply porblems is very low unless a power surge.
You have to check these things.
1. Stand by 5V available or not
2.If stand by 5V available press power and check B+ is getting or not
3.If B+ available check Horzontal oscillation
4.May be H-out transistor or video amplifier is bad.
Oct 14, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
User guide for technosonic dtr 110p
I need a remote control for a Technosonic VTR 105 TV. Can you help please. Paul
Mar 08, 2008 | Televison & Video
Televison & Video Logo
238 people viewed this question
Top Televison & Video Experts
