Question about Microsoft Windows Vista Ultimate Edition
Sonicwall program in Vista
We try to installed sonicwall program in Vista Operating System and shows following errer :
1. Failed to installed DNE, Abroting the installation
2. DNE Ext. code is : Oxe1230027
    Novelist:
  • 136 Answers
Here's a link to the cleanup tool located on SonicWALL's FTP site:
ftp://ftp.sonicwall.com/pub/techSupport/SWVPNClientClean.zip
If you are still having problems after using the cleanup util, try downloading the DNE demo here:
http://www.deterministicnetworks.com/Downloads/downloads.asp
Use the cleanup util again, then install the DNE demo first and Global client after that. The DNE demo is the virtual adapter piece that Global client uses anyway, you will just be installing it separately.
I got the clean up tool, ran it, rebooted, then ran the DNE demo installer then installed the VPN client and it worked fine.
Hope that helps!
Posted on Nov 06, 2008
Can not get Adobe PhotoDeluxe2.0 to install on windows 7. Worked fine on Vista
Adobe Photo Deluxe is an older program that does not seem to be compatible with Windows 7. you should contact Adobe to see if they have an updated version.
However, you can try the following to see if it will help.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1)Right click on the Program
2)Click on Properties
3)Click on Compatibility tab
4)Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Oct 04, 2013 | Microsoft Windows Vista Ultimate Edition
Wife is patient in local hospice. Has her own laptop and been given permission to acccess local wifi. Local service identified as Sonicwall. When we enter the password key (given to us by hospice staff)...
The inability of a client running Windows Vista to connect with a SonicPoint or any SonicWALL firewall (UTM) appliance running SonicOS Standard firmware is caused by a lack of a correct association on the SonicWALL between the computer running Windows Vista and its assigned IP address. Follow these steps to work around the issue by editing the System Registry:
WARNING: Exercise extreme caution when modifying the System Registry. Incorrect modifications could lead to an inability to boot your system. It may become necessary to completely reinstall your operating system.
  1. Click the Start button.
  2. Select All Programs > Accessories.
  3. Right click Command Prompt and click Run as administrator.
  4. Type regedit.exe and press enter.
  5. Go to the following location: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters
  6. Right click this entry and select New Dword.
  7. Rename the new entry ArpRetryCount (leave it set to 0 by default).
  8. Restart the computer.
  9. Reassociate with the SonicWALL. You should notice a successful connection.
Please print this out if possible, you may want to take your computer to a local repair shop to make this change if your not comfortable.
Mar 23, 2011 | SonicWALL Computers & Internet
I am using Win 7 32 bit and i can not get InDesing CS2 running any one know what i should do?Thanks
InDesign CS2 might not be compatiblw with the Windows 7 operating system. and InDesign CS4 is compatible with the Windows 7 operating system. You can check the following link for reference:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?type=Software&s=InDesign%20CS2
However, you can install the program in Windows Vista compatibility mode.
1. Right click on the InDesign CS2 setup file and select properties.
2. Click on Compatibility tab nad check the box for "Run this program in compatibility mode for" and select Widnows Vista operating system.
3. click on Apply and click on Ok.
4. Right click on InDesign CS2 and select "Run as Administrator" to start the installation.
Mar 10, 2010 | Microsoft Windows Vista Ultimate Edition
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
Hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
  1. Go to Java.com
  2. Click on the Free Java Download button, and start the installation process.
Sep 17, 2009 | Microsoft Windows XP Professional With...
My computer screen goes blank when I change the user
Hi, A(n) (recently) installed program is probably causing the problem, interfering with the service that takes care of the logon and -off process. To see if this is causing the problem, you can try the following:
Use this method if you remember around which date the problem started: 1. Click 'Start' -button 2. Type the following into the 'Searchbox': rstrui.exe 3. 'System Restore' opens 4. Select a date from which to restore your computer from. Needless to say, the date you choose should be a date on which you weren't experiencing the problem :-)
Use this method if you don't remember around which date the problem started: 1. Click 'Start' -button 2. Type the following into the 'Searchbox': msconfig 3. A system configuration window will show, where you can change the way Windows starts up 4. On the 'General' tab select the second option to boot diagnostically, loading only the standard devices and services. 5. Click 'OK' 6. Click on 'Reboot' 7. When you're computer has rebooted a message will show telling you that you've changed the way windows should start up and the system diagnostics window will show as well. 8. Since only standard devices and services have been loaded, try to logoff or change user and see what happens. If everything goes well, you know that a program, which should be a program you've installed before any problems started showing up, is causing the problem. If not, there's a corruption in the services of your operating system. 9. If everything goes well, you can start loading other services (from programs you've installed in your computer) one by one from the 'System configuration' window by clicking on the 'Services'-tab.
When you've found the the program that's causing the problem, delete it from your computer and select from the 'System configuration' window, 'General' tab the first option, for windows to start normally.
I hope this helps Good luck.
Cheryl
Jun 22, 2009 | Microsoft Windows Vista Home Premium with...
Hi I have Sony VAIO VGN NS135 laptop on which I have installed Windows Vista Ultimate Now there is error in booting and showing these lines Booting 'Windows Vista' acpi Vista Loader 2.1.2 Done! fallback 1...
This means that the operating systems was not installed properly...."Boot manager is failed... and ntldr is the main file... which help computer to boot up..." try reinstalling the operating system again...
Jan 12, 2009 | Sony VAIO VGN-NS135E/S Notebook PC
Problems with 2 operative systems in my new notebook
I've heard there has been a lot of issues running XP and Vista on the same drive.  I think Microsoft is trying to keep the drives working on one operating system because it's easier to fix.  It may only support XP in the configuration you have now.
You should check with Microsoft.com to see if Vista can (and will) support dual operating systems.
Oct 11, 2008 | HP Pavilion dv9000z Notebook
Windows vista
1. Disable Windows Update
a. Click on start
b. Click on all programs
c. Click on accessories
d. Click on Run
e. Type services.msc and press ok
f. Right click on "Windows Update"
g. Click on stop (Windows Update is now disabled)
2. Rename Software Distribution folder
a. Navigate to: C:/Windows/
b. Find the folder named: “SoftwareDistribution”
c. Rename that folder to something like “SoftwareDistribution.old”
d. Create a new folder called “SoftwareDistribution”
3. Enable Windows Update
a. Click on start
d. Click on Run
f. Right click on windows update
g. Click on start
If you are unable to find Software Distribution Folder, follow these steps before #2 above.
1. From the explorer window press the Alt key to view the file menu.
2. Click Tools
3. Select Folder Options
4. Select the View tab
5. Select “Show hidden files and folders”
6. Remove the selection from “Hide protected operating system files”
7. Click OK
Restart your PC and you should be good to go!
Jan 09, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
143 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
